Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 08-28-2009, 09:22 AM
micallen micallen is offline
05 Camry - Noise accelerating from stop
Save my marriage!!
My wife has been complaining about a noise coming from her 2005 4-CYL Camry for over a year. Once in a while I could hear it too. It was always when accelerating from a stop. I guess the best way to describe it is like a groaning vibration that lasts 1/2 a second. A mechanic told us it was likely the top-mounted torque strut motor mount. I replaced that and assumed that would do it. It didn't. In the past few weeks it's gotten much more pronounced. If you put it in drive (or reverse) and hold the brake down, it does it every time. The sound seems to be coming from the area of the lower left (facing the front of the car) near the pulleys - but not necessarily.
Any thoughts? I did a search and didn't see any similar issues.
Old 08-30-2009, 02:50 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: 05 Camry - Noise accelerating from stop
Sounds like one of your brake calipers may not be retracting fully. Does the car's steering wheel pull to one side when you accelerate from a stop? Also, does the car pull to one side when stopping? Any other vibrations or noises?
Also, what is the condition of the brakes? When were the pads replaced? It's a strange thing but some pads have the warning tabs only on one pad face and not both sides of the rotor. So if the caliper stops sliding to stay in line with the rotor (the caliper is mounted onto slide pins to keep the pad pressure even between the inboard and outboard pad), one pad will wear out faster, and if that pad doesn't have the warning tab, then you can get that grinding sound when that pad is worn away completely and the backing is contacting the rotor.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-30-2009, 03:12 PM
I don't think it's the brakes. Full brake service performed about 2 weeks ago. New pads, and new rotors.
It's coming from the lower left (if you are facing the car) of the engine compartment.
Old 09-03-2009, 03:17 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Try removing the surpentine drivebelt and repeat your shifting with the brake held. If the noise is gone, look at anything driven by the belt or even the belt itself. If it's still there consider engine mounts or the suspension.
Could have the tension checked on the surpentine belt or just replace it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 10-11-2009, 09:09 AM
DING DING DING... we have a winner. I took it to a mechanic that determined it IS the serpintine belt tensioner. He actually bought a new belt to see if maybe the belt had stretched and if that was the problem. It only slightly improved. It was definately the tensioner.
Tags
2005 , accelerating , noise
