Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-27-2009, 05:56 PM
chrisluna chrisluna is offline
96 Cutlass Supreme w/ humming noise coming from under the back of the car
I was charging my battery and I started hearing a humming noise but wasn't sure where it was coming from. Part of it sounds like its inside the engine but then I heard humming under the back of the car too. I went under the car and it sounds like its coming from the tank. Could the fuel pump be running? What can I do about this?
Last edited by chrisluna; 09-27-2009 at 08:17 PM. Reason: Different Possible problem
Old 09-28-2009, 12:11 PM
maxwedge maxwedge is offline
A990 racer
Re: 96 Cutlass Supreme w/ humming noise coming from under the back of the car
Pump should not run with the key off, sounds like a bad FP relay which would run down the battery.
Tags
1996 , cutlass , humming , noise , supreme
