Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 07-30-2003, 05:38 PM
cuzz cuzz is offline
just got an integra what should i do
i just bought myself a 94 integra ls its all stock w/ just under 100k on the original motor i got some cash so id like to make it fast now im new to this car deal ive been driving a truck all my life so i dont know mutch about 4cl motors and all that good shit so im leaving it up to the experts what should my mods be u can post replys or send me an email to [email protected] thx for ur guys help
Old 07-31-2003, 07:47 AM
Self's Avatar
Self Self is offline
Send a message via AIM to Self
How much money to spend? And how fast do you want to be? Able to beat Preludes? Able to beat Mustang GTs? Able to beat Camaro SS'? Able to be Vettes? Able to beat Vipers?
There's no replacement for displacement...No, not even a turbo.
Old 07-31-2003, 08:57 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
what kinda of inregra?
ls, gs, gsr?
well i would go turbo b\c i love turbo and the aftermarket is big on turbo parts for honda\acura, you can make big hp out of a turbo honda acura, i would say 350wheels hp saftely and reilably with the right supporting mods,
this is what i mean :
REBUILD INTERNALS
LOW COMPRESSION PISTONS, RODS
RE SLEVEED BLOCK,
TURBO KIT,
INTERCOOLER,
B.O.V.
FUEL SYS MODIFACTION, (450CC+ INJECTORS, UPGRADED FUEL PUMP, FULE PRESSURE REGULATOR)
MSD
S-AFC
3"EXHAUST
A DYNO TO TUNE IT ALL
MAYBE A PIGGY BACK ECU
NEW AXELS
CLUTCH
FLYWHEEL
i think thats all but i might of forgot some stuff
1
Shift_BOOST
97 s14
Old 07-31-2003, 10:05 AM
PWMAN's Avatar
PWMAN PWMAN is offline
ls, gs, gsr?
He said LS.
I would start with a turbo on stock internals. Building it up first would cost a lot at one time. Edelbrock is coming out with a kit for LS tegs, just wait for that one. The stock setting is probably like 8 PSI, even if you ran that and got a good 3'' exhaust system you should be pushing 230 HP to the wheels.
Old 07-31-2003, 01:15 PM
its an ls when is that new turbo kit comin out one of the guys i hang out w/ has a 94 ls that was rebuilt w/ a del sol heads upgraded ecu and some other miss stuff its quick but i wanna be much faster i got around 5k to spend right now and more later on so what should i do first the motor has just under 100k on it should i rebuild if so what should i do any ideas help
Old 07-31-2003, 02:29 PM
turbo2nr's Avatar
if you have 5k to spend now i would recomend re-builing the motor for turbo b\c the motor has 100k on it. and you can only boost 8psi saftly on the stock internals. and if you rebuild the internals you can go with a bigger turbo set-up run more boost and make more hp.
since you got more $ comming on the way you can put on a god turbo kit after the motor is built. i suggust after building the motor get the supporting mods for the turbo like injectors, pump, fule rail, and regualtor, a msd sys, and then drop on the turbo kit with a intercooler, b.o.v. 3"exhust, and if you want a external wastgate.
good luck
2
Shift_BOOST
97 s14
Old 07-31-2003, 04:09 PM
PWMAN's Avatar
If you plan to run more than 14 PSI you need to resleeve the block. Then get Eagle rods and JE or WISECO pistons. I would get WISECO, they come with their brand rings.
I didn't know you had that much $$$ or else I would have said to rebuild first, I was giving a cheaper alternative that still makes good power.
But get 9:1 compression, 8.5:1 will just cut out your bottom end power too much. You can run about 18 PSI with 9:1 compression on pump gas premium-93 octane. The Edelbrock kit can do 18 PSI no problem, that turbo that comes with it will spool EXTREMELY fast-especially with free flowing exhaust. Remember, you don't need any backpressure when you have a turbo. Plus that kit comes with a new manifold with a secondary fuel rail and 4 additional injectors. The only thing you need to get (besides exhaust)would be a high flow fuel pump, because your stock one won't provide enough fuel to compensate for 18 PSI.
Old 08-01-2003, 04:11 PM
alright i havent done any work to the car yet lets spend the money 1k or so at a time what should i do first with the first thousand and then we will work on spending the next 1k eventually we will drop the whole 5k and more on that later on but lets start small and go big so what should i do first w/ around 1000-1500 thanks guys for ur help
Old 08-01-2003, 09:34 PM
PWMAN's Avatar
You can buy the parts you're going to need for the rebuild. Don't waste the money on bolt-ons, you will probably have to take them back off when you put the turbo on anyway. Like intake and exhaust I wouldn't worry about. Maybe you could do things like upgrade your ignition.
But the Eagle rods and Wiseco pistons should run you about 750 dollars.
Old 08-01-2003, 10:22 PM
SleeperCivic SleeperCivic is offline
I wouldn't upgrade the ignition, I'd save for a standalone management system that has the ability to retard timing with boost. Honda/Acura (aka Honda) ignitions are very efficient and powerful enough for these motors. Internals would be VERY nice. I wonder what the Edelbrock will do to address fuel supply? It will probably be like the Civic kit with extra injectors, but supposedly their FMU in the kit retards timing with boost.
'04 SRT4 [Black] - 13.46 @ 102.9 (2.09 60') - R.I.P. 1999 Civic EX Turbo
.:ATP Up Pipe .:HKS SSQ w/Purple Insert .:K&N Typhoon CAI
.:Greddy Full Auto TT .:Greddy Profec B Spec II EBC .:Greddy Catch Can
.:AGP Billet Wastegate
.:Stock Ass-whoopin Installed
Dyno Proven - 234.6whp / 250.9tq 13.66 Video
Old 08-02-2003, 08:50 AM
PWMAN's Avatar
I meant things like plug wires and coil etc.
The edelbrock kit comes with a new intake manifold with a secondary fuel rail and 4 additional injectors, thats awsome. And yes it does come with ''state of the art electronics to control boost, fuel and timing retard''. That was taken from their catalog.
Friend just got one, what should she know? alfonso2501 Cavalier 10 11-11-2008 08:41 PM
Just Bought 1997 What should I be Aware of? Caddik Catera 1 01-26-2006 08:35 PM
just got a 91 integra, what do you think about this kit? 94tegRS N2O | Turbo | Superchargers 6 12-20-2004 01:30 PM
Just got it.. what should i do. HELP NerveAgent '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-16-2004 11:55 AM
I just got a 96 eclipse and I want the works, What should I do first? Eclipse9677 Street Racing 15 08-12-2002 07:29 AM
