Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 11-23-2001, 09:33 PM
NismoPC's Avatar
NismoPC NismoPC is offline
OEM '96 G20 Panasonic receiver speaker out or line out??
I have a '96 G20 with the OEM Panasonic CD/AM/FM receiver and the OEM Clarion amps/speakers.
Does the receiver have line level out or speaker level out going to the rear Clarion amps?
Trying to add an Alpine amp and Kicker Solobaric 10" to the stock set-up and I am hoping to be able to use a low level converter to run RCA's of the head unit into the amp.
Brandon
'96 G20 - modified
Old 11-23-2001, 10:47 PM
frogg's Avatar
frogg frogg is offline
Send a message via AIM to frogg
speaker level
Old 11-23-2001, 11:43 PM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
You sure bout that? Im preatty sure the out to the amps is line...
-Brian Jones
I got a snake man
Old 11-23-2001, 11:48 PM
frogg's Avatar
No, not completely sure. If you really want to know check the connections on the back of the head unit.
Old 11-24-2001, 10:04 AM
NismoPC's Avatar
Well I noticed on eBay that whenever someone is selling one of these OEM Panasonic units, they say your Pathfinder must have pre-amps. It is the same receiver that the Pathfinder for '96 have as well.
I am gonna assume they are line outs, but check them with a multimeter when I have the time.
THX!
Brandon
'96 G20 - modified
Old 11-24-2001, 12:43 PM
frogg's Avatar
Well if they were line outs, wouldn't they be _considerably_ bigger, where you could tell by just looking at them?
Line out, pre-amp, and preouts are just another wording for RCA
Old 11-24-2001, 01:50 PM
NismoPC's Avatar
Nope. Factory OEM receivers that have seperate amplifiers generally do not have RCA's even if they are line level outputs. My only concern is that the line level out signal of the Panasonic might be a higher level signal that a normal line out. That is why I will opt to install a line level converter just to be on the safe side.
At least most do not. From what I remember the new SE-R Spec-V Fosgate option has a head unit with RCA's, but I could be wrong.
You are thinking about aftermarket receivers with RCA outs. They have completely different standards than OEM.
Brandon
'96 G20 - modified
No Power to Rear Right Speaker In '96 Cavalier Douglas91 Non-Performance 2 06-21-2009 09:10 PM
'96 G20 Factory Alarm is made by Alpine? NismoPC Audio/Security 1 11-11-2005 06:30 PM
'96 G20 Factory CD player upgrade amp NismoPC Audio/Security 0 10-07-2001 05:18 PM
'91 intake cam in a '96 G20 NismoPC Engine 2 07-17-2001 10:31 PM
Best '96 G20 semi-stock suspension? cathandler Suspension 4 04-26-2001 11:54 AM
