Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Audio/Security
Audio/Security car audio, security.
Old 10-07-2001, 05:18 PM
NismoPC's Avatar
NismoPC NismoPC is offline
'96 G20 Factory CD player upgrade amp
OK. Can't seem to find any post in retgards to this.
Is it possible to run the speaker outs from the factory Panasonic indash CD player from a '96 G20 into a high level input amp (ex: Alpine 3522S Tri-Mode capable), then amplify the factory 2ohm speakers. This would bypass the factory Clarion amps (two) that are mounted under the rear deck in the trunk.
I am thinking of running all speakers off of the amp in a 4 ohm load (parallel) and cap them off. Run the Left front speaker/tweeter and left rear speaker at 4 ohm (parallel) and same for the right side, then run a 4 ohm 10" sub off of the tri-mode with a coil. No fader.
This is NOT a Bose system. It is the stock '96 G20 system that consists of a Panasonic AM/FM/CD head unit that powers the front speakers and two factory Clarion amps mouinted in the trunk that power the rears. All speakers are the factory Clarion set.
Any help would be appreciated.
Thanks
Brandon
'96 G20 - modified
My Factory XL-7 Cd Player RollersRights XL-7 0 02-20-2010 11:31 AM
'96 G20 Factory Alarm is made by Alpine? NismoPC Audio/Security 1 11-11-2005 06:30 PM
OEM '96 G20 Panasonic receiver speaker out or line out?? NismoPC Audio/Security 6 11-24-2001 01:50 PM
'91 intake cam in a '96 G20 NismoPC Engine 2 07-17-2001 10:31 PM
Best '96 G20 semi-stock suspension? cathandler Suspension 4 04-26-2001 11:54 AM
