Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-24-2003, 08:25 PM
jpjenkins69 jpjenkins69 is offline
changing rear speakers
I have a 1997 Toyota Corolla, and I need to change the rear speakers. I know how to do it all except for removing that rear piece of felt/carpet stuff. If anyone could get me any method of doing it that doesn't tare up the material like I keep almost doing then I would really appriciate it. Thanks.
Old 07-28-2003, 10:57 AM
oppositesleeper oppositesleeper is offline
Send a message via AIM to oppositesleeper
why do you need to remove the carpet airnt the factory speakers just sitting on top so when u unscrew them the should just pull right out, or maby yours is different them mine i dont know i had 6x9s installed in my car
Old 09-08-2003, 07:01 PM
L3BAN3Z3 L3G3ND L3BAN3Z3 L3G3ND is offline
Send a message via MSN to L3BAN3Z3 L3G3ND
Cool
I had da same problem wen changin da rear speakerz in my rolla. Mine weren't 6x9" dey were 5.5" to take out the rear carpet piece you need to take out the anchorage point which iz a bolt that goez from the top of the parcel shelf and through the other side of the frame. To do this you need a high powered oxygen pump wiv the socket attached as this bolt cannot be taken out easily. Another thing too, it may be illegal to do this, unless you take it to a professional installer. After you take this out, the speakers are mounted in pods just unscrew disconnect rewire your new speakers and mount back in.
In my case I couldnt get the anchorage point out so I took of the speaker covers by carefully ripping them of the rear piece, BUT I'd advise you dont do this unless you are planning on re-skinning the rear shelf or installing pods as the gap that is left around the speaker doeznt look too good. Im at the moment looking at reskinning my rear shelf with vinyl or material or maybe making custom pods that would cover the surface.
The following is a link to a page that has instructions on making pods there are many others but this is the easiest I hav found so far.
http://www.geocities.com/lincandyr/
The instructions are made for front doors but the concept can be easily modified for rear shelf. You may even be able to redesign the pods for 6x9s if u want.
Good luck! msg me [email protected] if u need any more help or advice whether for installation or for products etc...
1998 P71 rear speakers don't work. Moose666 Crown Victoria 0 06-26-2009 05:14 PM
Need help changing rear speakers in a 98 GT Bassett72 Grand Prix 3 08-19-2005 06:38 PM
Changing rear speakers in 1991 Corolla sedan drs5633 Corolla/Matrix/Voltz 5 02-07-2005 05:14 PM
Changing rear speakers Dyson99 Mégane 2 06-03-2004 09:24 AM
92 Civic Change Rear Speakers xception79 Car Audio 2 02-04-2004 02:47 AM
