Changing rear speakers in 1991 Corolla sedan
Thought I was a wimp for looking for help instead of just poking around, but after some searching I see it's a common problem.
Trying to replace the rear 5.25 inch speakers in a 1991 Corolla. I can pry the grill off, but the speaker enclosures appears to be firmly attached to the rear deck; I can see the ends of mounting screws from underneath but no access to the screw heads from above. I suspect that I must take out the rear deck to get to the screw heads, but I've learned from painful experience not to just start prying unless there is no other option. Anyone out there have any hints? Thanks for any help, David |
Re: Changing rear speakers in 1991 Corolla sedan
i did this in my 90 corolla. there are tabs on the rear seat bottom that pop out and then pull up on the back seat and then you can take the rear deck out and then you will be able to access the speacker bolts.
Re: Re: Changing rear speakers in 1991 Corolla sedan
I'm just wondering if it's true if you can put 6 1/2" speakers instead of the 5 1/4". If it's not, I might just get 6x9 boxes with speakers and mount them with velcro in the trunk. |
i replaced my stock rears with 6 1/2" you have to make your own mounting brackets for them though. mine were just cut out of wood.
dynamat and foam
