Old 07-23-2003, 05:28 PM
Musclecarclub's Avatar
Musclecarclub Musclecarclub is offline
Wheel and Tire sizes
Looking to upgrade my tires on my GS. The stock rims are 14x6 (why did muscle cars have such tiny wheels?). I currently have on 215/75/14 tires - want to go wider to help my launch at the track. I had another GS with 225/65/14 on the same style 14x6 wheels - it seemed OK although handling was sloppy. To move up to 15" wheels cost some serious $$. Anyone here put anything wider than 215 tires on their 14x6 wheels? Should I just bite the bullet and shell out $1,000 for 15x7 wheels? Would 15x8's fit on my GM A-body? What wheel and tire sizes are you guys running?
1971 Buick GS Convertible
350-4bbl w/ 3-speed Auto
1 of 599 made
Modifications: None - Totally stock!
Former owner of:
1969 Buick GS 400 Convertible
Modifications: 430 4bbl. V8 (from a '68 Riviera), Stage 1 spec Carb, headers, 2 1/2" exhaust, transmission shift kit, and column tachometer - to name a few ...
Old 10-26-2003, 12:27 AM
geno96Z71 geno96Z71 is offline
If you're looking for better handling, 15" rims are definitely the minimum. A-bodies have cavernous rear wheel wells and room in front as well- you should be able to get 265/50R-15 on 15x8's all around. I've even seen guys stuffing 295/50R-15's in the back of their Chevelles. Of course, the right wheel offset is critical there. Have your local wheel shop get your ride up on the lift and fit the rim you're going to go with- most GM intermediates like at least a 4" backspace.
Geno
Old 10-26-2003, 01:52 AM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
I know on my Nova, you can stuff a 275 tire on a 15x8 on the rear. Front I don't think you can go much over 235 with out rubbing problems.
I'm going to need as much rubber out back as possible... with 377ft-lbs @ 2000rpm leaving on a 2000stall converter will result in nothing but smoke.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Engine Swaps,wheel and tire size,and Rear brake disc conversion LX sleeper Escort 1 07-11-2004 01:51 PM
Wheel and Tire size Whitebread Tires and Wheels 10 05-08-2004 03:49 AM
wheel and tire size leejam86 Prelude 2 04-27-2004 12:02 PM
Need advice on wheel and tire size scotty2 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 07-30-2003 08:08 AM
Offset For P10 Wheels and Tire Size TRBOBRK Cosmetics 11 11-10-2001 06:07 PM
