Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Cosmetics
Cosmetics interior, exterior, wheels.
Old 11-09-2001, 01:44 PM
TRBOBRK's Avatar
TRBOBRK TRBOBRK is offline
Question Offset For P10 Wheels and Tire Size
I am thinking of getting 17x7.5" Team Dynamics DTM. Local shop can get them cheap and I like the bbs/touring style.
If I go with a 17x7.5" wheel what offset should I run? I have heard that 45 would be a good offset but some other people are saying 38 or 40. What would be best?
Tire width on a 17x7.5" wheel. Most people are saying either 205-45 or 205-40 is a good size for a 17" wheel. Is that wide enough to fit a 7.5 inch wheel?
Colin Gillespie - 1993.5 Nissan Primera - NWG20s
Old 11-09-2001, 02:48 PM
Mythos's Avatar
Mythos Mythos is offline
Send a message via AIM to Mythos
not sure about offsets on a P10 - if they are anything like a P11, 42mm is a good fit and yes a 205 tire WILL fit on a 7.5" wheel.
Old 11-09-2001, 08:57 PM
poppy_morenito's Avatar
poppy_morenito poppy_morenito is offline
Send a message via AIM to poppy_morenito Send a message via Yahoo to poppy_morenito
I have 205/40/17 on my p10 wishing I had gone 215/45/17.... my tires look kinda skinny
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
GROUND CONTROL/KYB ADJUSTABLES
17" VOXX MGR 205/40/17
Old 11-09-2001, 09:46 PM
megamotors megamotors is offline
Send a message via ICQ to megamotors Send a message via AIM to megamotors Send a message via Yahoo to megamotors
Re: Offset For P10 Wheels and Tire Size
P10
size offset tire
15 x 7.0 38 195/60/15
16 x 7.5 35 to 40 250/45/16
17 x 7.0 or 7.5 38 to 40 215/40/17
18 x 7.0 or 7.5 38 to 40 215/35/18
i hope this helps you
Old 11-10-2001, 10:03 AM
P10DET's Avatar
P10DET P10DET is offline
Re: Re: Offset For P10 Wheels and Tire Size
Originally posted by megamotors
P10
size offset tire
That offset is wrong for a 7.5" wide wheel. So is the tire size.
George Roffe
Houston, Texas USA
00 328i
91 SE-R (well modded)
84 944 SCCA ITS race car under construction
"I fear all we have done is to awaken a sleeping giant and filled him with a great resolve"
-- Admiral Yamamoto, December 7, 1941
Old 11-10-2001, 10:11 AM
P10DET's Avatar
I have 17x7.5 ADR M-Classics. They are 45mm offset They are a pretty much perfect fit. A 42mm offset if you can find it might work a little better, but you will run the risk of rubbing the fender lip in the rear. Any smaller offset won't work well on the P10 in the rear.
I am running 205/40-17 and you cannot get a tighter fit. In fact, when I went from Scummytomo HTRZ-II tires to Yokohama Pradas in the same size, I had to adjust the camber in the rear a little and file part of the spring perch to get about 1-2mm clearance. Any larger tire will not fit.
George Roffe
Houston, Texas USA
00 328i
Old 11-10-2001, 01:15 PM
well i'm runing 18x7.5 42 offset with 215/35/18 momo sport
and it fits perfect! on a P10
Old 11-10-2001, 01:54 PM
JustinP10's Avatar
JustinP10 JustinP10 is offline
Send a message via ICQ to JustinP10 Send a message via AIM to JustinP10 Send a message via Yahoo to JustinP10
Geo- Did you have issues with rubbing with a larger tire on the spring perch? I'm thinking about trying to find a ser of Spec V wheels for my G, as they are the right bolt pattern, and the offset is close (47mm) and with a spaer, they should fit fine. But I was unsure about tire sizing. I have the GC/AGX setup, and since i don't have aprings sitting on the perches, i wouldn't feel bad about grinding that away (most of the way that is, i would still keep enough for the GC collar to rest on) Is this a possible solution? Or should I just look at, and figure on getting smaller tires? Thanks BTW. I have a couple pictures uploaded to this site, with spec v wheels photoshopped on my car
http://groups.yahoo.com/group/Team-N...V%20wheels.jpg These are 16"'s exactly, as i just overlayed them on top of my exisiting 16" rims.
http://groups.yahoo.com/group/Team-N...20v%20rims.jpg these are bigger, I'm guessing probably equivalent to 17-18" rims, but i'm really not sure, as there isn't really an easy way to measure on a picture.
Justin McClanahan
95 G20
15.4 @ 91.4mph (2.4 60ft )
143.7whp and 131.4 ft.lbs
Primera (10:1) Intake Cam, HS CAI, HS Header, UR Pullies, 19* Timing, ACT, Lightened Stock Flywheel, GC/AGX, Pacesetter Short Shifter, and more stuff...
Old 11-10-2001, 03:17 PM
TRBOBRK's Avatar
I have a stock suspension, will I have to change anything? I just want to bolt the wheels on and go.
So there is only 1mm of clearence? Do you ever scrape with people in the back. I don't usually carry people but when I do I cram 5 people in the car
I like Dunlop sp9000s I had them on my Volvo and they were quiet and I never lost traction unless I wanted to powerslide a corner. I wish the g20 was rear wheel drive. Drifting in a front wheel drive car scares me.
What about 17x7" and 45mm? The wheel would be about 12mm thiner or is the problem tire size here.
I may want to go with the 17x7" Monza wheels anyway so I wonder about that fittment also.
Old 11-10-2001, 03:26 PM
Mythos's Avatar
If your running on stock springs a 17x7 with a 45mm offset and 205 tire will be fine. The only time minor changes in offset become a priority issue is when you lower your car, b/c of the decreased clearance a millimeter here or there can make a world of difference. You could probably go as high as 48mm offset on a 7" wheel with your stock suspension. As far as tire size goes the P10 correct plus size is 205/40 17. If you want to go for a bigger size (215/45 17, etc.) then you will have to recalibrate your speedo, b/c it will have a significant percentage of error.
This link will allow you to plug in various offsets and tire sizes and let you know what kinda clearance you will get.
http://www.tolan-hoechst.com/cars/tirecalc.htm
Old 11-10-2001, 05:32 PM
P10DET's Avatar
Interesting. Like I said, I'm running 17x7.5 45mm offset with 205/40-17. I have 1-2mm clearance and I had to work to get that. The offset for one of our wheels is wrong. I know for sure that ADR M-Classics that size with tires that size would not even mount on my car.
George Roffe
Houston, Texas USA
00 328i
Old 11-10-2001, 06:07 PM
It seems with my Intrax./ AGX setup I still have room for a taller wider tire in the back .
It the tires lokk really skinny from the back too. I saw an IS300 with 17's going 215/45/17 and a mazda MP3 with the same... maybe it is just my untrained eye ....
93.5 G20
JDM SPEC SR20
JWT POP CHARGER
Engine Swaps,wheel and tire size,and Rear brake disc conversion LX sleeper Escort 1 07-11-2004 01:51 PM
wheel and tire size leejam86 Prelude 2 04-27-2004 12:02 PM
Wheel and Tire sizes Musclecarclub Engineering/ Technical 2 10-26-2003 01:52 AM
Need advice on wheel and tire size scotty2 '88 - '91 Civic | CRX | Wagon | Shuttlee 2 07-30-2003 08:08 AM
OEM P10 wheels and tires for sale dbsborg Classifieds 1 10-03-2001 07:53 AM
