Old 07-16-2003, 05:27 PM
1989CivicSi's Avatar
1989CivicSi 1989CivicSi is offline
Send a message via AIM to 1989CivicSi
b18a1 swap help please !!!!!
im putting a ls in a 91 si and need some help, everyone i have talked to saids that i can use my stock clutch cable, but the clutch cable is to short so i have to pull up on the clutch lever (on the bottom front side of the tranny. Also is there any wiring i have to do? or does the si harness work perfectly. Last but not least the driver side axle is sorta sitting to the left and almost hitting the shock.
can someone please help me, i cannot find any sites about this swap and i would for someone who has done this swap before to help.
thx
Wes
91 Honda Crx Si Metallic Blue Pearl
90-91 B18a1
Action Stage 3 clutch
Clutchmaster 8lb aluminum flywheel
Place Racing motor mounts
Revo Short shifter
Short ram intake
2 1/4 exhaust
17in Tenzo R Shu 4's
Kumho Supra 712's (cheap tires )
Old 07-16-2003, 05:37 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah you can use your stock clutch cable but it needs to be modified, ok on the clutch cable there is a black rubber cover which u see on the outside, underneath that theres a metal spiral tubing, then inside that is the actually clutch cable itself. what u gotta do is cut off about an inch of that metal tubing and rubber covering, and that should make it long enough, i forget exactly how much u need to cut off but its around an inch or so
or u can just buy a integra clutch cable
also if your clutch lever goes up really high and it fits thats all good. its kind of hard to explain but when u pull up on that clutch lever, there should be free play up and down until it hits the clutch engaging point. kind of get it, like pull up on the clutch lever and when it stops, thats the point where the clutch starts to engage.
Team Lonely Drivers
Old 07-16-2003, 08:10 PM
what about the wiring?
90-91 B18a1
Revo Short shifter
Short ram intake
2 1/4 exhaust
Old 07-17-2003, 01:16 AM
91civicDXdude's Avatar
i dunno how you guys did it, but i just used my stock clutch cable. it worked fine. The wiring should be almost a direct plug in swap. All the plugs are the same since its an obd0 engine, like the d16a6. use your Si harness and transfer it over to the B18, should plug right in.
Old 07-17-2003, 01:42 AM
the motor is sitting at an angle like \ but not as bad, i used place racing mounts and hte car has never been wrecked, i know that the driver side mount is upside down. what could be the prob? this swap is starting to make me mad
90-91 B18a1
Revo Short shifter
Short ram intake
2 1/4 exhaust
Old 07-17-2003, 01:49 AM
upside down?? wtf?
Old 07-17-2003, 02:01 AM
im mean i know its not upside down lol
90-91 B18a1
Revo Short shifter
Short ram intake
2 1/4 exhaust
Old 07-17-2003, 05:51 AM
redmanjd redmanjd is offline
the stock cable works you have to pul the arm althe way up then hook the clutch cable on
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 07-17-2003, 03:45 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
about the motor mounts, you should try to loosen every mount without taking the bolts completely out. then from there try moving the motor as much as possible, and then tightening everything back up. if that doesnt work, you can always ream the holes on the passenger side mount, and make them eggshaped, and then from there you have adjustability
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Motor Swap Help Please!!!! crabby760 Engineering/ Technical 12 11-17-2003 11:47 PM
1993 sentra motor swap help please LiqrSicc Sentra | 200SX (USDM FWD) 4 10-27-2003 10:41 PM
GSR swap help Please edwinyee82 Engineering/ Technical 2 10-14-2003 10:48 PM
Trannie Swap? HELP PLEASE Joe98Eclipse Engine, Transmission and Drivetrain 1 09-03-2002 03:40 AM
Engine Swap help please 88hondaowner '88 - '91 Civic | CRX | Wagon | Shuttlee 1 08-17-2002 11:39 PM
