Old 07-12-2003, 01:26 PM
Alvan9 Alvan9 is offline
Send a message via AIM to Alvan9
Dash Help
I am about to buy a 4 Door 2000 Honda Accord, and was wondering where I can get a custom dash. Underneath the radio the dash just stops. I want to be able to extend the dash down to the drive shaft hump. To add my Alpine DVD player and Alpine EQ. The radio is a double din slot, so I can run my CVA-1004 and CD player. If anyone knows what I am talking about, would you let me know.
Thanks
Old 07-12-2003, 10:02 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
I know that this is not what you're looking for...but have you ever considering doing some of the work yourself, with some fiberglass? If fiberglassing isn't your thing...the good people at Vibrant performance might have what you need. Here is an ad for their custom dash..
"Get rid of that dull, tired, everyday, stock dashboard that's taking up space and weighing down your ride. Vibrant has a new universal fiberglass dashboard that weighs less than 12 pounds and will fit into virtually all sport compacts. It is easy to install because it uses the existing OEM mounting points, and it is 52 inches wide by 21 inches high by 12 inches deep. The dash is also paintable, so custom looks are easily achieved. We know you've been dreaming about that mural of the naked Aztec chick with the snake wrapped around here. Now you have somewhere to put it."
The dash looks very nice when installed. I have seen a CRX with one in it..and it looks like a very nice fit. Here's the vibrant performance contact info..
(905) 564-8644
www.vibrantperformance.com
I hope I helped somehow..good luck!
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
water in passenger floor and sloshing sound behind dash, HELP paramed214 Blazer 24 08-04-2005 07:05 AM
Everything's in German in my dash???? HELP??? john525i 5 Series 4 06-27-2004 09:34 AM
dash help justchad25 Caravan | Voyager 0 05-09-2004 05:36 PM
Cant get the ciggarett plug off my dash help please Harryc8786 Malibu 3 12-14-2003 04:40 PM
Blowing Fuse on Dash HELP HELP fats619 Blazer 3 11-05-2003 02:20 PM
