Blowing Fuse on Dash HELP HELP
The fuse blows for the temp,amp,fuel,speedometer gauges.The brake light is coming on with the i p in red. Also when replace the fuse it blows right away. Could it be my alternator.Need help Please Help
Re: Blowing Fuse on Dash HELP HELP
Most likely your alternator is not at fault.
There is a short to ground on the circuit that blows the fuse.. DO NOT...I repeat DO NOT install a larger fuse or something to bypass the fuse. You will need to trace the harness and look for the affected wires.
Why do you never have enough time or money to do the job right the first time, but enough time and money to do it again? Got all the certifications 25 years ASE Certified Master Technician GM WCT Yea..I work at a DEALERSHIP....got a problem with that? Want to diagnose cars like the Pros? FOR SALE: OTC Perception 2 channel Labscope (badged as a Matco Reality) This is my personal labscope that I use to diagnose waveforms, like new, comes with leads and training video PM Me for details |
Short
Where do I look for this short? Is it live wire or ground? I looked under the mat but have not taken the seat out? i have put a set of booster cables to the motor and run the others to the firewall & the frame still blown fuse.These is driving me nuts I am ready to take it to a garage and pay big buckto fix it PLEASE HELP
Re: Short
Running jumper cables is not going to help anything...you are just wasting your time.
If you want to diagnos and repair this yourself, you will need a good service manual with wiring diagrams. What is the name of the fuse that is blowing? Is it the guages/idle fuse? if so there are about 10 componants that are powered by this fuse. This is a power wire that is shorted to ground..either by the insulation being chaffed somewhere in the harness or a componant that is drawing more amps than the circuit is rated for.
