Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 06-29-2003, 12:33 AM
mrchaos mrchaos is offline
Best pistons for Turbo b16a
I was looking at Arias or Wiseco but I will entertain others. Give me your thoughts. Looking to run somewhere between 9.0:1 and 9.5:1 CR with Crower rods.
Thanks
Old 06-30-2003, 03:47 PM
civicgsr_T4_60-1 civicgsr_T4_60-1 is offline
Send a message via AIM to civicgsr_T4_60-1
me personally, i run arias. They work fine. They've held the abuse up to 500whp for me so far. I can't complain
EDIT: 9:1 and crower rods is a good combination.
00 civic with bolt-ons, i swear
Old 07-03-2003, 03:07 AM
MatikaS MatikaS is offline
Send a message via AIM to MatikaS
how much psi i can run w/ 9.5:1 or 9.0:1 pistons?
VTEC I like it!
SORRY FOR MY ENGLISH
Old 07-03-2003, 07:54 AM
you could run around 30+psi with both as long as the tuning is good. But you will probably want to resleeve the block.
Old 07-03-2003, 08:38 AM
with what comression rait pistons guys runing mostly and how much psi?
VTEC I like it!
Old 07-03-2003, 08:58 AM
i run 9:1 pistons. Daily I run 10psi, but could run at least 1bar on pump gas. On race gas I run 23psi, but only because i'm at max boost on my wastegate spring, i need a bigger one. 30+psi will be no problem.
Old 07-03-2003, 09:58 AM
turbo2nr's Avatar
turbo2nr turbo2nr is offline
Send a message via AIM to turbo2nr
civicgsr what fuel mangament are you using to support 23psi??
Shift_BOOST
97 s14
Old 07-03-2003, 10:22 AM
Hondata S200b, hondata p28 with obd2 connectors pre built in, delphi 880cc injectors, aeromotive 500lb/hr pump, aeromtive fpr, inline pro fuel rail, -10an line, -8an return. I believe that is it.
Old 07-03-2003, 10:44 AM
turbo2nr's Avatar
wow sounds good..
you drive your car daily driven.. it muct be tuff on a race motor like that..
im guessin you have atleast 2 different fuel maps 1 for racing and 1 for daily driving..
p.s. do u have a pic of this beast?
1
Shift_BOOST
97 s14
Old 07-03-2003, 10:47 AM
Right now it's only tuned on race fuel, so pump gas it's running extremely rich. I will end up getting a new map just for pump gas though.
Old 07-03-2003, 12:34 PM
turbo2nr's Avatar
nice any engine shots by chance
or am i askin to much
llolz
nice care..
1
Shift_BOOST
97 s14
Old 07-03-2003, 12:44 PM
I don't have any today. I will take some this weekend in full detail of the car. I don't care, as long as i don't have to show my tags.
Old 07-03-2003, 01:14 PM
turbo2nr's Avatar
tru.. good job
1
Shift_BOOST
97 s14
Pistons for turbo engine fordperson Forced Induction 17 06-26-2005 05:57 AM
pistons for turbo and nitrous geisi13 N2O | Turbo | Superchargers 24 04-04-2005 06:09 PM
Which one is the best ECU for turbo b16a (Gen-1) civicfreak1 JDM Motor & Parts info/chat 15 10-07-2004 11:09 AM
B16 A2 what compression pistons for Turbo b16_beast Let's get Technical! 20 09-28-2004 01:18 PM
what is the best engine for me b16a sir or b18c djkarlkani Integra 3 07-26-2004 10:22 AM
