Old 06-26-2003, 01:28 AM
RacinPlaya77 RacinPlaya77 is offline
Need Some Amplifier advice....
Ok Everyone...I have just purchased (4) 12" volfenhag 1000 watt subs....each can take 500 watt rms...I also need some help on what other speakers i should get like 6x9's some tweeters...or what not...but the main question is what kind of amp or amps will i need to purchase to get the full power from these subs...i also need to know what other equipment i will need if i use multiple subs ...i just need some help on purchasing the equipment for a really strong nice sounding system....I would greatly appreciate ne help u ppl could give me thanx.......
Old 06-26-2003, 10:17 AM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
you need 2 1000 watt amps, mostlikely 2 ohm stable I assume, what are the specs on those subs
www.cloudcity.deviantart.com
Old 06-27-2003, 11:43 PM
SPECS :
FS 30HZ ,
QTS 0.526 ,
QES 0.614 ,
QMS 7.698 ,
VAS 56 L ,
XMAX 16MM ,
EFFICIENCY ( 1W/1M) 89.58 ,
SD PISTION SURFACE AREA 0.0491M ,
RE DC RESISTANCE 3.2 OHM,
IMP DUAL 4 OHM,
POWERHANDLING CONTINOUS 500 WATT ,
MOUNTING DEPTH 6.3 Inches ,
MOUNTING DIAMETER 11.65 Inches
heres the specs on the subs...and what other speakers will i need to have a strong system..and withthose speakers will i need another amp ....or will i need ne thing else for use of multiple amps
Old 06-28-2003, 09:09 AM
Haibane's Avatar
full power, phoenix gold makes a great class D amplifier that pushes 1000 watts, you can come across that for about 500 dollars if you search
Old 06-28-2003, 04:02 PM
Deakins's Avatar
Deakins Deakins is offline
2x1000w@1ohm or [email protected]
The ringing of the division bell, have stopped...
AF User Guidelines
Old 06-28-2003, 08:35 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
you will need some type of midrange and tweeter speakers, or a coax for the front. You will need an additional amp for these, ans some way to crossover the frequencies
Old 06-30-2003, 12:47 AM
AirAllen01's Avatar
AirAllen01 AirAllen01 is offline
Send a message via Yahoo to AirAllen01
I'd go with Memphis Class D amps. The MC1000D amp is 1-ohm stable and Memphis' highs are awesome. They are LOUD and CLEAR.
Have you ever danced with the Devil in the pale moon light?
I'm your Huckleberry.
Don't hate the playa, hate the game.
Unreal Tournament 2004 Mexican Mafia «MM»Sternum
Visit AF's Sketching and Drawing Forum.
http://www.automotiveforums.com/vbulletin/f1155/
Need some Amplifier selection help AlmightyFireCrotch Car Audio 2 12-15-2005 10:47 PM
Hey there fellow Import/240sx fans! I need some friendly advice jml917 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 6 10-26-2002 03:07 AM
i need some bodykit advice!!!! PiTi Exterior | bodykits | Lighting 6 06-07-2002 12:06 PM
need some car advice Airborne Street Racing 4 03-13-2002 11:47 PM
I need some quick advice..... Shanan General Discussion 4 11-14-2001 06:51 PM
