Old 06-10-2003, 06:56 PM
Deejay27's Avatar
Deejay27 Deejay27 is offline
What size wire for detail???
I was wondering what size wires are used to detail a 1/20th scale F1 engine? I was thinking about picking some up but have no idea what size to buy.
Jimmy
Current Project
"Tamiya 1/24th scale Enzo"
Completed Projects
"1/12th scale Renault FW14B"
"1/24th scale McLaren MP4/7"
Old 06-10-2003, 07:41 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
The most I can say is you can't do much harm if the wire is too thin.
Old 06-10-2003, 08:44 PM
935k3's Avatar
935k3 935k3 is offline
Re: What size wire for detail???
Check out the 30 gauge wire wrap wire available at Radio Shack.
Old 06-10-2003, 10:24 PM
Jay! Jay! is offline
Horizontally Opposed
Re: Re: What size wire for detail???
Wire or wire wrap? I've been asking at several Radio Shacks for 30g wire....
Hierarchy of Subaru:
(Click to see mine!)
Old 06-11-2003, 05:10 AM
935k3's Avatar
It says wire wrap wire on the package. Wire wrap wire is used in electronics by using a tool that wraps the wire so tight around a square pin on a circuit board that it cuts into the insulation and makes contact, so no solder is necessary. Radio Shack has sold it for years.
Old 06-11-2003, 05:38 AM
Decs0105's Avatar
Decs0105 Decs0105 is offline
Registered User
use modeler's .45mm black wires !! other colors also availible !!!
Old 06-11-2003, 09:28 AM
DSM-Mark's Avatar
DSM-Mark DSM-Mark is offline
Just consider the scale, if you want to be really accurate. 0.45 mm on a 1:20 car translates into 9 mm wire. Probably a little big, but it should work pretty well.
I work slowly!
Old 06-11-2003, 11:41 AM
Decs0105's Avatar
Registered User
i said that because the winner of tamiya con 2003 used them !!! i think i will use them for my Williams FW-24!! look at modelersite.com and click on the "how to build a winner Tamiya F310-B" article !!! that is totally awesome ......
plug wires for detail questions aaroncrombie Car Modeling 10 07-08-2003 01:54 PM
What size tires for stock rims 99TrackerConv Tires and Wheels 2 11-01-2002 03:19 PM
what size wire to hook up amp with? 94civic Car Audio 7 05-03-2002 08:30 AM
what size tires for 14's? scofa Tires and Wheels 5 02-01-2002 08:16 AM
what size exhaust for the wrx is too big? wrxfl Impreza/9-2x/Outback Sport 2 01-18-2002 09:43 AM
