Old 07-07-2003, 03:34 PM
aaroncrombie's Avatar
aaroncrombie aaroncrombie is offline
plug wires for detail questions
Searched and saw it recommended to use 30 gauge wire from radio shack, but how to attach to distrib/engine? Any tips??
Thanks.
Old 07-07-2003, 07:39 PM
primera man's Avatar
"P-Man"
You will need to buy a pin-vise and small drill so you can drill holes in the heads/dist.
Or you can buy pre-wired ones already done.
View All My Models Here.
Old 07-07-2003, 08:40 PM
Juan Robles's Avatar
Juan Robles Juan Robles is offline
Also you will need super glue to atach the cables. It is a good idea to subscribe to recieve a speed shop catalog like summit or Jegs to have reference where the cables go.
Also it make the wiring more realistic if you follow the firing order of the particular engine you are building.
Current projects: , 49 Merc (100%), 99 Celica (100%), 72 Corolla (100%), Lexus IS 300 (100%)
NEED MORE PROJECTS!
Old 07-07-2003, 09:39 PM
935k3's Avatar
935k3 935k3 is offline
If using the Radio Shack 30ga wire use about a number 77 drill for the holes. Use a pin in the pin-vise to center mark each hole.
Old 07-07-2003, 11:43 PM
IwannaDRift's Avatar
IwannaDRift IwannaDRift is offline
Send a message via Yahoo to IwannaDRift
I used some wiring from somekind of electrnic board
"It makes you feel gooood.."
FAQ's of life....
Old 07-07-2003, 11:49 PM
CamaroSSBoy346's Avatar
CamaroSSBoy346 CamaroSSBoy346 is offline
Send a message via AIM to CamaroSSBoy346
my super ghetto way: drill 1 big hole in distributer, glue 8 wires (all 8 wires cover the hole) [i mostly wire v8's anway] and then tuck the wire behind the exhaust header
2002 F150 SuperCab FX4 6" Fabtech, 3" BL, Detroit locker, Edge tuned, Yukon 4.56s, 37" Nittos, Harley lights, Depo fogs, 8K HIDs, Powerstop brakes
1992 Lincoln Mark VII LSC 302 H.O, A9L ECU swap, 65mm TB, 73mm Granetelli MAF, FRPP 30lb injectors, Walbro 255, MSD ignition, Powerdyne BD11 supercharger, Efans, T-5 swap w/ FRPP flywheel, Ram HDX clutch and adjustable Steeda clutch quadrant, 4.10 gears, Nitto NT555R radials
2000 OBS Tahoe Z71 6k HIDs, 33" Goodyears. 280k mile daily beater
Old 07-08-2003, 07:26 AM
freakray freakray is offline
AF Modelrater
What about the ninth wire?
There is a wire to the coil too.....
AF User Guidelines
Old 07-08-2003, 08:42 AM
Thanks! I'll get a pin vise then and some bits.
Old 07-08-2003, 08:51 AM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
I was about to say the same thing...
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 07-08-2003, 10:55 AM
008's Avatar
008 008 is offline
The Camaro in the pic has HEI ignition and therefore only has 8 wires. So he's excused, for now. Don't show us a non-GM V8 without a coil wire.
Old 07-08-2003, 01:54 PM
I use wire that i bought at a arts/craft store made in a variety of colors. I get 40 yards for $2.00 USD.
AF MODELING FAQ
"Oh what a feeling.- Toyota
Need Wiring info for E350 Cruise Module jdemaira Econoline 0 01-18-2011 02:16 PM
replaced my plugs and wires on my 2002 Gc sport 3.3 chevyn0va1 Caravan | Voyager 4 10-24-2010 06:38 PM
plug wires for 4g64? crazy_ugly_coyote Eclipse 2000+ 3 08-23-2004 06:06 PM
spark plug wires for b16a1? crxsirpr '88 - '91 Civic | CRX | Wagon | Shuttlee 4 02-22-2004 01:23 PM
What size wire for detail??? Deejay27 Car Modeling 7 06-11-2003 11:41 AM
