Old 07-10-2012, 04:18 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Front Right Signal out - bulb & socket OK
Since winter & cold & damp & rain, my left front signal won't work.
Left Back works.
Every once in a while the front signal works then not.
Where would I look for a bad connection ?
Probably some connection corroded and needs scraping - but where ?
The PHOENIX is still going along ! I LOVE THIS CAR !
DoctorBill
Old 07-10-2012, 05:49 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: Front Right Signal out - bulb & socket OK
clean the socket and i believe it has a plug about a foot begind the socket where it hooks to body wiring harness. good to see you on here again Doc
Old 07-11-2012, 01:54 AM
Metro Mighty Mouse's Avatar
Metro Mighty Mouse Metro Mighty Mouse is offline
You didn't mention, did you change the bulb? They sometimes will look fine, work occasionally, and the filament is actually broken.
MMM
Old 07-11-2012, 04:03 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
Ground for the front markers and turn signals is on the render just behind the headlight. A single black wire on each side that is bolted to the inside fender. Loosen that up, wiggle it around, and tighten it back down. Same should be done with every ground you can find, every two years or so.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 07-11-2012, 06:27 AM
Jeff Collision Jeff Collision is offline
Check the electric circuit to make sure that the fuse and relay are working properly. Also you need to check your turn signal bulb, flasher and socket.
Old 07-12-2012, 06:00 PM
DOCTORBILL's Avatar
Geo Metro Lover
Nice to come back to the Metro Forum !
I checked the bulb - It is good.
Scraped the socket out and greased it.
I will look for that ground wire and the socket about a foot back.
Here where they spray snow melter all the time, metal corrodes like crazy.
I'll let you all know if I find what is wrong.
95 degrees outside and I'm not doing so well in this heat.
How do those people in the middle East live in such temperatures ?!
DoctorBill
PS - Been into working with a small Lathe. Lot of fun !
Old 07-18-2012, 01:27 PM
DOCTORBILL's Avatar
Geo Metro Lover
Whatever is causing this, I can't find it !
Clue....
Today I went to the Post office.
Making a left turn, I clicked on the left turn signal and it clicked
fast like it does when a light is out.
As I started the left turn, the signal went back to clicking slowly.
So, I think that whatever is wrong is in the steering wheel electrical stuff.
Now it is clicking slowly - for a while - then it goes back to fast clicking.
I suppose I need to pull off the steering wheel and look at the switch (?)
Any ideas as to what parts to look at ?
DoctorBill
Old 07-18-2012, 01:30 PM
Crvett69's Avatar
switch is sealed, can't really do much with it. if you take it apart stuff will go everywhere, did you find the plug where socket harness attaches to body harness?
Old 07-18-2012, 01:51 PM
DOCTORBILL's Avatar
Geo Metro Lover
If you mean the two wire one about 6 inches behind the front left turn signal, yes.
Appears to be OK.
DoctorBill
Old 07-18-2012, 02:06 PM
Crvett69's Avatar
i would unplug it and chechk for corrsion and plug and unplug it a few times to make sure it has good contact. there is a chat room here now too if you want to say hi
Old 07-19-2012, 03:45 AM
Woodie83's Avatar
I don't think it's in the switchgear, that's going to turn on the turn signals or not, no possible way it could turn on one and not the other. You need to get a shop manual and trace the wiring. I'd start at the bulb by checking to see which connection is missing, 12V or ground.
Woodie
Old 07-24-2012, 01:24 PM
DOCTORBILL's Avatar
Geo Metro Lover
Where would the left front turn signal wire branch off of the main trunk harness line ?
Yesterday, I replaced my 6 year old battery and ground cable with new.
Cleaned up the left fender ground connection and greased it before reassembling.
Turn signal still doesn't work....
DoctorBill
Old 07-25-2012, 07:48 PM
DOCTORBILL's Avatar
Geo Metro Lover
No entry....
Old 07-25-2012, 11:22 PM
red39715 red39715 is offline
Had the same problem on my 92 Metro. The problem lies in the connector from the light to the body circuit. It is not the connection between connectors but the connection between wire and pin or socket. I just pulled on the wires and got a good connection. Not the best way but it did work. If you can get the pins out of the socket you could recrimp them.
Old 07-26-2012, 04:08 AM
Woodie83's Avatar
Check out page 7 of this document: http://swift.crime.one.pl/pliki/sche...swift_1993.pdf It appears that the combination switch plugs into the junction box (fusebox under the dash) and then separate wires come out of the junction box for the front and the rear turn signals. Problem must be in the junction box (unlikely), at the connectors at the junction box, or in the wire between the junction box and the light.
Again, when troubleshooting this sort of wiring problem, there is no substitute for a genuine Factory Service Manual. That would show you the exact path including locations of various connectors along the way.
Woodie
Front turn signal bulbs keep burning out Lachfa F-Body Problem Diagnosis 2 08-03-2007 12:42 PM
98 Concorde bulb sockets for front turn signal jwb2 Concorde 1 03-28-2006 11:22 PM
Changing front turn signal light bulbs mikebocc X5 4 01-17-2006 03:19 PM
2001 Jetta front turn signal light bulb VW Jettaboy '97 - '03 3 03-13-2005 10:23 PM
