Go Back   Automotive Forums Car Chat > Chevrolet > Uplander
Old 07-07-2012, 01:08 AM
trannyman52 trannyman52 is offline
Brake Light,,directional lights not working!!!!
Brake lights do not work,,,though center back door light does work,,,,directional lights ,,,front and rear do not work but have indication of them working on dash,,though dash flasher acts like a shorted bulb,,,hazard lights also do not work though dash does flash as they are working.....Any Ideas ?????,,,,this is a 07 uplander-LS ....thanks...gbaum
Old 07-07-2012, 11:38 PM
phipps phipps is offline
Check the multi function switch in the steering column. Similar thing happened to my mom's Astro and it turned out the multi function switch was bad.
The Following User Says Thank You to phipps For This Useful Post:
trannyman52 (07-08-2012)
Old 07-08-2012, 09:37 AM
Re: Brake Light,,directional lights not working!!!!
Thanks,,,,I will be checking with 2 guys that work for a GM dealer on their thoughts,,,was questioning the body control module as the problem,,,nice to hear if some one has had the same issue,,instead of blindly ripping stuff apart....
Old 07-21-2012, 12:15 AM
just to update you ,,,,problem was the body control module,,,replacement was not bad,,,required a re-set of the anti-theft system,,,radio theft system,,,re-learn engine crank sensor........
Want to paint my brake calipers on 07 town car cobrahd1999 Town Car 1 02-08-2013 04:43 PM
2005 gtp lose of brakes roman1978 Grand Prix 9 07-26-2012 10:58 AM
odometer works intermittently and sometimes stops Garys57 Beretta 6 07-22-2012 08:12 PM
ac not so cold anymore!!! hot in Chicago!!! 75srv180 Equinox 3 07-10-2012 10:00 AM
2006 Toyota Works Mate Ute 2.7 litre Lozza1968 All Other Models 0 07-06-2012 04:03 PM
