2005 gtp lose of brakes
I was driving yesterday and noticed when i press the brakes the car tries to stop but then the pedal starts fading away and goes all the way back i tried pumping several times its even verse. I checked the fluid level looks normal no abs light what can this be. I have fairly new brakes in the front and old ones needed to be changed. I was shocked good thing i was not going fast. This happened after a an hour of driving and it was very hot in NY about 95 degrees. Please gide me in the right direction. I left the car home today did not want to take a chance driving it. Feels like a loss of pressure.
Re: 2005 gtp lose of brakes
Regards, Sarah GM Customer Service |
If the pedal goes to the floor, and you are sure there is no fluid leak, then you have a bad master cylinder. Need to have the brake system checked for leaks, living in New York its very possible you have a rusted through brake line.
Absolutely do not drive the vehicle......As GMtech1 said, if there are no EXTERNAL LEAKS, then it's probably a bad master cylinder
it turned out to be a Master cylinder. Has anyone had any experiance with aftermarket ones or should i get an OEM GM one
My experience is that you get what you pay for when it comes to master cylinders. I like to compare brake parts to a motorcycle helmet. If you have a 10 dollar head, buy a 10 dollar helmet! Get the OEM master.
just orderd oem one
GMtech1, can I borrow this one:
If you have a 10 dollar head, buy a 10 dollar helmet! |
Have at it, Tech II, enjoy!
Update replaced a master cylinder and she is all good now
