Go Back   Automotive Forums Car Chat > Chevrolet > Equinox
Old 07-06-2012, 11:19 PM
75srv180 75srv180 is offline
Cool ac not so cold anymore!!! hot in Chicago!!!
My 08 Equinox has about 92,000 on it now. Ive noticed that the ac isnt blowing as cold as it used to. I bought one of the "premium" recharge kits with the gauge on it, hooked it up and it was exactly where it was supposed to be! can the refrigerant just not work well after some miles? can I let some out of the low pressure side and re-fill it with new (improved) r134? I didnt want to let any out fearing a drop in pressure would cause damage to the system.
Old 07-10-2012, 01:03 AM
Ruley73's Avatar
Ruley73 Ruley73 is offline
Re: ac not so cold anymore!!! hot in Chicago!!!
I bet it is working fine. It is just that hot out. I would recommend using the recirc setting to help cool things down.
Also, keep in mind there are certain situations in which the A/C compressor is temporarily turned off. For example, any time you floor the gas pedal the compressor will be turned off until you let up.
My rides:
2007 Chevy Equinox LT FWD
2018 Chrysler Pacifica Touring L
"If women don't find you handsome, they should at least find you handy!"
- Steve Smith (Red)
Old 07-10-2012, 08:24 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Pitch the one hose one gauge so called improved pemium recharge death kit..
As said extra hot weather will cut down on cooling.
What is the output vent tempt?
MT
Old 07-10-2012, 10:00 AM
Tech II Tech II is offline
As MT-2500 said, let's find the efficiency of the system......
Make a note of the ambient air temp, and possible humidity in the air.....
Now drive the car on the highway........have a temp probe stuck in one of the registers......
Turn the system to "VENT", no A/C......turn temp lever to full heat......should get at least 140-150F.....
Now turn the lever to full cold.....should get ambient air plus 10F.....if you get these temps, this means the temp door is working......
Now turn the A/C on(not MAX).......temp should drop AT LEAST a minimum of 30F.......so if the air coming out of the vents at full cold with A/C off was 85F, the temp should be 55F or lower.....when temp stabilizes, turn it to MAX and see if the temp drops lower....
Give us your readings from this test......
'89 K1500 starts cold or hot, not warm karattop General Discussion 0 05-06-2009 10:30 AM
98 SL A/C not cold anymore JScottB SC/SL/SW 7 07-08-2008 08:27 PM
hot outside , not cold inside billysandra Aurora 1 06-23-2008 09:02 PM
97 JXI starts when engine cold but not when engine hot joshodonn Sebring | Sebring Coupe | Convertible 0 03-19-2005 07:20 PM
A/C not blowing cold anymore jeffbeck Grand Cherokee | Grand Cherokee SRT8 0 08-23-2004 02:36 PM
Tags
air , conditioning
