Go Back   Automotive Forums Car Chat > Chevrolet > Beretta
Old 07-06-2012, 09:32 PM
Garys57 Garys57 is offline
odometer works intermittently and sometimes stops
Hello all !
My odometer works intermittently and sometimes stops. I have read somewhere that it is a faulty vehicle speed sensor....is this correct. I have a 1991 Beretta GT. Can anyone give me direction where I can locate this faulty sensor? Is it on the transmission or???????
Any help is greatly appreciated !
Thanks
Old 07-07-2012, 09:48 AM
Tech II Tech II is offline
Re: odometer works intermittently and sometimes stops
If your odometer stops working, but your speedometer is ok, chances are it's the cluster....
Old 07-07-2012, 07:56 PM
Thanks for the response.
So where is the trouble in the cluster? Can you describe what to look for
and how to make the necessary repairs to make the odometer work again?
Or do I need to change the cluster ?????
Old 07-07-2012, 09:27 PM
Ha,ha, as a tech when I ran into a problem like this, it was the cluster....techs do not take clusters apart looking for circuit board or soldered joint problems......just not cost effective......
Old 07-07-2012, 10:24 PM
So the only option I have is to replace the cluster.........is that correct?
Old 07-08-2012, 04:31 PM
Unless you want to take it apart and look for something obvious.....
Old 07-22-2012, 09:12 PM
I've noticed that the odometer works fine at highway speeds 100 km/hr (60 mph) but at lower speeds it does not ! Anyone have any experience with something like this?????
silverado problem stall and sometimes stops kenwood guy Silverado 9 07-04-2010 06:16 PM
1991 GM Speedometer, tripometer, odometer and cruise quit working. Janett_vh Grand Marquis 3 05-04-2009 01:36 AM
Turn light stops working intermittently for my 2001 Alero 01AleroUser Alero 4 02-23-2007 05:15 PM
Power Seatbelts work and sometimes don't work etjon 626/Capella/Capella Wagon 0 09-28-2004 01:52 AM
