Go Back   Automotive Forums Car Chat > Plymouth > Horizon
Old 07-02-2012, 12:39 AM
bucketman2001 bucketman2001 is offline
87 dying after stopping
i have an 87 that dies after it starts unless i keep my foot on the gas and when coming to a stop. when driving, it jerks. it has gradually gotten worse all day long. i stopped at a stop sign and it died once and didnt do it all day long. i was low on gas today and i thought it was just because of that but it it was still the same after putting a half of a tank in. any info would help me out a lot. thank you.
Old 07-12-2012, 11:10 AM
typesix typesix is offline
Re: 87 dying after stopping
Likely that the carb has air leakage, these carbs were known for being troublesome, may need rebuilding. Had to rebuild the carb on my former 1981 Dodge Omni(Horizon twin). Check all vacuum lines for cracks and leakage, that may another cause. You can carefully spray carb cleaner to check for vacuum leaks around the carb and lines.
Another option if it is vacuum leak around the carb is to put sealant around the outside to seal the leak, did that to my Dad's 1974 Dodge Dart carb and it worked.
Good luck
Old 09-20-2012, 09:38 PM
denisond3 denisond3 is offline
You have probably found the problem by now, but I would have thought it might be a malfunctioning 'servo' that keeps the throttle slightly open when the ignition is on, and lets it shut when the ignition is off, so it doesnt diesel after being turned off. Some of these were vacuum operated, and there would be a vacuum solenoid on the firewall to the passenger side of the motor, or were electricaly operated, with a solenoid mounted on the driver's side rear of the carburetor..
And yes, they are finicky carburetors when they get to be 25 years old.
Old 09-27-2012, 01:18 PM
i actually havent solved this problem yet lol my car is sitting outside and just got started up yesterday after not being ran for months. someone told me that the torque converter may be locked up but it still runs in park sometimes (key word some times) but we have put new spark plugs in changed the roter under the distributor cap, changed the carb and idol valve and fixed the cracked vacuum lines. everything short of actually dropping the tranny and looking at the converter. we may have missed a cracked line. im thinking of scrapping the damn thing lol but i want to try every option before i do anything drastic like that.
98 Malibu LX 2.4; dies after few miles ; will start again after about 1/2 hour vin.b Malibu 7 11-09-2010 11:21 AM
93 LeSabre Shakes and Dies After Stopping FlyerFan LeSabre 2 10-20-2007 05:53 PM
Battery died, car died after driing through puddle HypnosisLady Taurus | Taurus Wagon 13 01-15-2006 06:42 PM
89 GP dies when stopped and in drive sabrinamsmiley@sbc Grand Prix 1 02-13-2004 07:54 PM
89 GP dies when stopped and in drive sabrinamsmiley@sbc Grand Prix 3 10-30-2003 03:30 PM
