| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
Shudder while turning right
Hi
This is my first post, lets hope I get am able to solve my problem. I have a Prado and whenever i turn right while parking, the car shudders, it does not happen when I turn left and it happens only when I am parked and I turn right and accelerate, not while I am driving. Any clues? Last edited by helpneeded1; 06-28-2012 at 11:17 AM. |
Re: Shudder while turning right
I'm not familiar with a "Prado." Google shows a Toyota Landcruiser, so I'm going to assume its a 4WD truck.
A shudder when turning a 4WD vehicle generally indicates a binding of axles, u-joints, or something inside the transfer case. It could be sticking in 4WD due to a bad shift motor or something. AWD and automated 4WD systems have issues with mismatched tires. See if your tires are at the same tread depth all around. The worn tires spin faster and send false slippage signals to the control unit, which proceeds to command 4WD when it isn't needed. This can cause shudders and jerking. See if you can remove the front driveshaft. Some models allow you to do this without losing fluids. That should eliminate the 4WD system as the cause of your problem. |
“In three words I can sum up everything I've learned about life: it goes on.” ― Robert Frost |
![]() Could it be something to do with tie-rods or wheel bearings? |
Try 2 high and see if the problem changes. 4 high is usually intended for use on slick or wet roads. 4 Low is for off road use or deep snow.
Bearings and tie rods tend to make noise when turning while already moving. A bad tie rod should also cause wandering at high speeds and a sometimes a clunk/rattle when hitting bumps at low speeds (assuming that the rod end is very worn out, a little play won't be noticeable). Bearings can cause the same rattle or wander, but its usually harder to notice. A shudder like you describe usually indicates a binding component. |
Check the sub frame brushing and motor mounts. Maybe the motor and sub frame is moving slightly as you turn and creating the shudder you speak of.
