Old 09-23-2004, 10:04 PM
firefiretiger firefiretiger is offline
Answer to noise in front end while turning right
Had a metalic whirling noise on 99 grand prix only when turning to the right. If you killed the engine and let the car coast the noise stopped. Turned out to be a bad starter. The starter drive was hitting the flywheel on turns to the right.
Thanks Lawrence Hall Chevy in Abilene Tx for the fix. Rick the service manager said the problem appears on Chevy Luminas as well.
Firefiretiger
Old 09-24-2004, 12:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Answer to noise in front end while turning right
Are you sure it's not a motor mount allowing the engine to move causing the starter to rub the rack or somethnig?? The starter is attached to the motor, so it would rub regardless. The direction of travel would have no effect on whether or not the starter drive hit the flywheel!!! Are you sure this guy knows what he's talking about?
