Go Back   Automotive Forums Car Chat > Panoz > GTRA / GTWS / GTS
Old 06-24-2012, 08:59 PM
Cobra4B's Avatar
Cobra4B Cobra4B is offline
Rebuilding Dad's Panoz; LS1 swap
We can rebuild him... we have the technology...
Done with the post race inspection/next race prep on the Z06. Time to push the Panoz in.
Taking it all apart to paint the chassis/interior gloss white.
Wing was surprisingly heavy; all metal.
The neighbors love me.
That's sitting at an odd angle...
Piece of shit Ford
Will update and bug Eric a bunch as I progress.
~Brian
Brian B.
Panoz GTRA - LS1 swap in progress
#4 Z06 - NASA ST3/TT3
The Following 2 Users Say Thank You to Cobra4B For This Useful Post:
mlwhite (01-10-2014), PanozDuke (06-24-2012)
Old 06-26-2012, 08:24 AM
Cobra4B's Avatar
Re: Rebuilding Dad's Panoz; LS1 swap
No more hacked up 15+ year old EFI harness and wiring job...
Brian B.
Old 06-28-2012, 11:27 PM
Cobra4B's Avatar
It's broke good... it'll be interesting to see if something in the bottom-end failed or if the block just let go from being too weak for the application. It was only making around 370 rwhp. Piece of shit.
Brian B.
Old 06-30-2012, 08:08 PM
Cobra4B's Avatar
Body panels all off...
My buddy Sonny brought his son Mason over to check out the racecar
Brian B.
The Following User Says Thank You to Cobra4B For This Useful Post:
PanozDuke (07-01-2012)
Old 07-12-2012, 01:10 AM
Cobra4B's Avatar
Radiator support and front suspension all removed. Getting ready to pull the engine.
Front suspension assemblies
Brembos going to get rebuilt and fresh powdercoat
Brian B.
Old 07-12-2012, 03:08 AM
NZGTRA17 NZGTRA17 is offline
Originally Posted by Cobra4B View Post
Thanks Brian, that brake caliper photo confirmed it...............I thought our calipers were silver before our 4 hour race in the weekend. Now all 4 are a uniform bronze/gold colour from the heat (I was running ducting to the rears as well from a side scoop). Wouldnt believe it if I hadnt seen yours!!
Kel.
Kel M
Panoz GTRA #17
New Zealand
The Following User Says Thank You to NZGTRA17 For This Useful Post:
Cobra4B (07-12-2012)
Old 07-12-2012, 08:06 AM
PanozDuke PanozDuke is offline
Brian,
Thanks for all these photos. Really good reference for how these cars are put together and what is involved in a full disassembly.
Following up on my other post about reducing interior heat, did you add the exhaust wrap and if so how much difference did it make?
Mike
Old 07-12-2012, 08:45 AM
Cobra4B's Avatar
Originally Posted by PanozDuke View Post
Brian,
Mike
We had the side pipes coated in a 2000 degree "turbo" coating and then we wrapped them. Car was still very hot. I think part of that was due to the location of the muffler right next to the occupant and how close it was to the tub to fit the big Flowmaster in there (in an effort to make the car quieter). This time I'm going to use a 6" diameter magnaflow race muffler and put it much farther forward on the pipe. Probably just aft of the forward exhaust hanger. Car will be loud, but Dad's in his 60s so going deaf isn't a concern
When I cut the cats out of the mid-pipe on my Z06 I left that area unwrapped so I could keep an eye on my shade-tree mechanic welds over time. Laying up under the car with it running, the difference in radiant heat from the wrapped areas vs. unwrapped sections is astounding. So I'd say yes, it makes a big difference.
Brian B.
PanozDuke (07-12-2012)
Old 07-12-2012, 10:22 PM
Cobra4B's Avatar
Trying to figure out if the bottom end failed and the crank snapped. Or, did the block fail first and then take out the bottom end? The thing that pisses me off is that it never completed a track weekend in 2011 w/o some kind of issue. The car was shifted at 6000 rpms and was making around 370 rwhp:
March - Filling up catch can and custom dipstick gets stuck.
July - Breaks a valve spring. Shop used old springs that were on the heads that came off the blown up 5.0 that was swapped out.
October - Car chucks the water pump pulley. Bolts weren't safety wired and I had no idea that was something that had to be checked. Car is my father's and I just don't know Fords like I do LSXs.
February (2012)- Catastrophic failure on the back straight of VIR at top of 4th gear; no warnings, oil pressure fine.
It started ticking when my dad got it back from the valve spring replacement in July last year. Shop swore it was a lazy lifter, but I felt otherwise. It sounded like rod nock to me, but they were adamant it was fine. Of course when it shit the bed in February they said it was that the stock block was too week for the power.
Supposed lifter tick (probably rod knock) - http://youtu.be/VxQLDHpGgeA
Any tips on what to look for as I dig into this thing? Very curious if the block failed or if the crank/bottom end failed.
Brian B.
Old 07-13-2012, 09:00 AM
Brian,
I only have limited personal experience with engine meld downs. I think you will know better when you get a good look at the crank and rods. If the crank is broken, one or more rods broken and bearing(s) melted, it was probably a rod letting go and taking out the block. If the bearings are basically OK and no rods are broken, the block probably failed. From my knowledge, the late model 5.0 blocks are considered safe to about 400 hp. At the rear wheel numbers you had, it was marginal. Mine (331) is about 100 hp less than yours, but I intend to push it up another 25-50 hp. I'm comfortable with that and have taken all the precautions I can think of (28 oz. recipricating assemby with good parts, main studs and girdle, careful block prep. My bet is that you know a rod knock when you hear it. 6000 seems well within the means of the reciprocating assembly and I think the horse power should have been OK. The 400 limit is based on extreme shock loads like power shifting , drag race launches with slicks. I doubt you guys ever did that to the motor. The lateral crack along the side of the lock is a typical 5.0 block failure, but some of the other damage is consistent with a crank or rod failure.When the pan comes off and you look at the bearings it should be clearer. Since my motor is a 5.0 stroker, I'm very interested in your conclusions.
I've never laced the water pump pulley bolts, just used a standard lock washers, grade 5 or 8 bolts and torqued to spec. At the rpm you were turning, it should have been under nothing but a normal load. No special concern regarding the Ford versus GM set ups.
Mike
Old 07-19-2012, 05:44 PM
Cobra4B's Avatar
The eagle has landed. LS1 crate motor for a GTO.
Brian B.
Old 07-24-2012, 03:15 PM
eric1h eric1h is offline
looking "good". Working on getting the motor mounts boxed up and sent out for the LS motor!
Eric H (in case you couldn't guess)
GT-WC #22 (now #62 and Blue)
The Following User Says Thank You to eric1h For This Useful Post:
Cobra4B (07-24-2012)
Old 07-30-2012, 02:12 PM
Cobra4B's Avatar
Engine torn down. Only found one bent valve. Other than that heads are fine. Can't get the cam out though... comes 1/2 way out and get stuck. I can see a loose cam bearing and it could be bent, who knows... off to the metal yard it'll go.
Trans cover removed... access is nice to have.
Got it out. Need to finish taking the trans off and seeing if the clutch is worth a heck. If the main shaft isn't messed up the trans will be refreshed and for sale. It's a Tremec 3550 and one of the few things on this car that never gave us any trouble.
Almost ready to roll the frame out for some power-washing then on to the welding and fitting everything.
Brian B.
Old 07-31-2012, 07:33 AM
Eric,
What did you find after the oil pan was off?
Mike
Old 07-31-2012, 08:03 AM
Cobra4B's Avatar
Haven't taken the pan off... got the engine/trans out and put it on a tire. First order of business is to get the chassis ready for the powdercoater which means test fitting the new engine/trans and doing any/all welding i.e. filling holes, relocating mounts/brackets, and welding in a proper harness bar.
~Brian
LS1 swap?, awd swap? Confedneck Performance 0 04-17-2007 06:03 PM
lt1 vs. ls1 swap into 3rd gen(1990) matt11583 Camaro Discussions 11 01-04-2005 10:17 PM
total cost of ls1 swap matt11583 Camaro Discussions 9 08-15-2004 01:53 PM
3.8L to LS1 swap cost. GoBears Camaro Discussions 4 04-28-2004 01:01 PM
ls1 swap in a 68 camaro? Trancebot Camaro Discussions 17 12-14-2003 02:53 AM
