Old 08-13-2004, 10:40 AM
matt11583 matt11583 is offline
total cost of ls1 swap
what would be teh total cost of doin a ls1 swap into a 89 iroc. including labor, the engine, and any other parts i might need. (driveshaft, ect...) would the stock tranny last a while, until i have more money for a t-56 and will that be enough for it, and how will the stock suspension do??? and anyone have a good place to buy it?? thanks for your help.
Old 08-13-2004, 10:43 AM
ridge_runner ridge_runner is offline
Send a message via AIM to ridge_runner Send a message via MSN to ridge_runner
Re: total cost of ls1 swap
atleast 8 grand probably
Old 08-13-2004, 10:46 AM
your suspension should be fine but i would get new struts... and i dont think the bolt patterns for the tranny are the same for a 80s sb and the ls1
Old 08-13-2004, 11:45 AM
twdz28 twdz28 is offline
stock trans of your car will not work, drive shaft will... Do it yourself and have much more pride in the car after you done as well as saving a ton of money... You could get a eng, trans, wiring harness, ecm, motor mounts, and trans mounts for around $2500 to $3000 with low miles from a salvage yard or eBay...
Here is a link to help you understand more about it...
http://thirdgen.org/techbb2/forumdis...?s=&forumid=20
Old 08-14-2004, 06:07 PM
Chevyracincamaro's Avatar
Chevyracincamaro Chevyracincamaro is offline
a lot...
*Better power-to-weight ratio than a C6 corvette*
Old 08-14-2004, 06:13 PM
Re: Re: total cost of ls1 swap
Originally Posted by Chevyracincamaro
a lot...
times 3
Old 08-14-2004, 11:52 PM
Dober89 Dober89 is offline
A guy over at thirdgen.org did an LS1/T56 and rearend swap and I think he got it done by Thirdgen Resource.
I think his bill was around 14k.
Old 08-15-2004, 08:28 AM
how much would it cost if i changed it to a lt-1
Old 08-15-2004, 11:52 AM
prolly around the same amount, maybe a little cheaper cause you can find an LT1 for less than an LS1. but i dont think it would cost 14k if you did it yourself, sure if someone else does the work, but yourself i would say around 8 or 9, maybe 10k...
Old 08-15-2004, 01:53 PM
DiabloGT's Avatar
DiabloGT DiabloGT is offline
Banned
if its 8k, then just put 8k into the stock engine and you can smoke any stock vette
