Old 06-22-2012, 10:30 PM
reefgeorge reefgeorge is offline
Pressure test heater core
I intend to pressure test my heater core in place to confirm a leak before tearing in to my dash. I have read that we should not test the core at the full pressure cap rating because the core may get damaged. I have read 5-8 pounds max. Any guidance is appreciated.
Thanks,
George
2002 Blazer, 4 dr, 2wd, 199K miles
2003 Rav4, 4 cyl, 239K miles
2012 Mailibu, 4 cyl, LTZ, 85K miles
Old 06-24-2012, 10:43 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Pressure test heater core
Thanks,
George
You can not believe all you read.
Let some of it go in one ear and out the other
Test it at full pressure cap pressure.
Around 17-18 lbs is safe to test.
The heater core is always under full rad pressure or what ever pressure the cooling system is running at.
MT
Old 06-24-2012, 11:20 AM
Do you suggest a pressure system test pump set up or air compressor as the source for pressure? Got any suggestions on a rig to get me from compressor or pressure tester to the heater core pipes?
Thanks,
George
Old 06-24-2012, 04:01 PM
MT-2500's Avatar
AF - Advisor
Thanks,
George
Most parts places will loan or rent you a pressure tester.
But if you have a air compresser and a air pressure regulator with pressure gauge you can T the pressure regulator into the heater hose or small water hose.
MT
Heater Core Help emmaandleesmom SC/SL/SW 3 04-01-2010 11:43 AM
2002 Saturn L 300 heater core replacement Dadsvan LS/LW 0 03-22-2010 11:17 AM
97 k1500 z71 silverado, BLOW THE HEATER CORE???? kokopelli85 Silverado 6 01-12-2010 07:38 PM
1998 ACHIEVA Heater Core darkflame64 Achieva 1 12-31-2009 03:05 PM
smell antifreeze - NOT heater core samdavon Dakota 1 12-11-2009 12:19 PM
