Old 01-12-2010, 07:51 AM
kokopelli85 kokopelli85 is offline
Question 97 k1500 z71 silverado, BLOW THE HEATER CORE????
i have a stock 97 1500 z71 silverado with a 350 vortec. ok... so the heater hose that goes from the fire wall to the intake manifold busted loose at the quick connect coupling. i swapped it out for a brass nipple and figured i'ld run a regular hose. couple buddies say this will blow the heater core one after another. is this true? doesn't really make sense to me why it would... could some body please explain? thanks
Old 01-12-2010, 09:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 97 k1500 z71 silverado, BLOW THE HEATER CORE????
Your buddies are full of crap.
MT
Old 01-12-2010, 10:01 AM
j cAT j cAT is offline
if you used a generic non OEM heater hose this should work ..
the heater core gets damaged with coolant neglect...
Old 01-12-2010, 02:43 PM
yea didn't make sense to me but supposedly one of them went thru 7 in one month due to changing the pressure hose out to a brass nipple in the intake with a regular hose ans clamp... so yall are sure thats b.s.? lol thanks for the responses guys
Old 01-12-2010, 04:54 PM
the only other item to blow out the heater core/ radiator is the coolant pressure cap..this should be 15psi...max....
aftermarket caps of higher than 15 psi would cause damage...seen this before..better to use 14 psi than go higher than 15psi if neceassary.
Old 01-12-2010, 05:32 PM
J-Ri's Avatar
J-Ri J-Ri is offline
y so yall are sure thats b.s.?
Absolutely 100% pure BS
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 01-12-2010, 07:38 PM
thanks guys... heater is hooked back up lol
Tags
core , heater , hose , intake , pressure
