Old 06-22-2012, 05:56 PM
foul_owl foul_owl is offline
Question Can my car pull a trailer?
Hello,
I was wondering how to calculate how much weight my car can pull (trailer + cargo)
I have a 1981 Cadillac Eldorado with the Olds 350 5.7L diesel engine.
I know diesels have a lot of low end torque, but that doesn't help me get raw numbers down. Eg, would it be possible to pull 500 lbs? 2000 lbs? I'll be driving on residential streets/arterials, so 25-30 mph tops.
Specs:
http://www.automobile-catalog.com/au...p#.T-T5oZGk7mg
But no GVWR rating.
Thanks a bunch!
Old 06-22-2012, 06:37 PM
vgames33 vgames33 is offline
Re: Can my car pull a trailer?
I recall reading that 500-1000 lbs was safe for most vehicles.
That engine wasn't known for being a powerhouse or anything, but it should pull a smaller trailer just fine. Consider adding a transmission cooler, especially if this will be a regular thing.
Old 07-01-2012, 12:26 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
1000 should be no problem as long as you don't mind going slower than normal
Dragging people kicking and screaming into the enlightenment.
Old 02-10-2013, 11:58 AM
Tami.P Tami.P is offline
To find out how much your car can pull the weight, firstly check out the weight of the trailer which is always given on the Vehicle Identification number plate and then add that weight with weight of the load. You will get total weight your car will pull.
Now, check out how much your car can pull the weight, and the best method to check it out is read the vehicle manual.These manuals also provide detailed limitations of towing trailers.
Old 02-10-2013, 06:30 PM
maxwedge maxwedge is offline
A990 racer
They were rated for 1k when new. 120hp!!
Old 02-20-2013, 08:27 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
When in doubt, read the manual. 1000 lbs is a reasonable limit for short hauls. Make sure the diff and trans fluids are good. Some older vehicles required thicker viscosity gear oil when towing...again, check the manual if you have it.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
how can I pull out my car radio? wolfy123 206 0 09-01-2007 08:47 PM
Can I pull a camp trailer? daintydecker Caravan | Voyager 1 08-21-2007 09:32 PM
Can I pull A uhaul with my car? Clyde96 Grand AM 4 02-13-2005 10:22 AM
Check engine light is on. How can I pull codes? Johnny5oh General Discussion 2 03-10-2004 09:00 PM
