Old 06-22-2012, 12:08 PM
NJFrank NJFrank is offline
Angry Passlock yet again - Please read need help
If Anyone can help it would be appreciated.
I did the passlock bypass inline resistor method, not switch) on my alero and things seemed good. The one exception is that the security light would not turn off.
Well the other day the car decided not to start (usual passlock behavior heard the injectors prime, then nothing no ignition click nada). relearn procedure would not engage, then car decided to start appx 5 minutes later.
I checked the BCM connection when home a/p bergerweb , maybe I should try a new resistor?
Any suggestions on what I may be missing. Ill also post in the Grandam forum as the same car.
btw 2002, 3.4 V6 model
This is the car that convinced me to never own another GM product
Thanks
Old 07-01-2012, 02:17 PM
bman44 bman44 is offline
Re: Passlock yet again - Please read need help
I bypassed with a switch in 2005. It has started every time since then.
Old 07-02-2012, 05:46 PM
I changed resistor, disconnected battery, checked contacts on bcm, cant find any bad fuse.
Security light stays on, re learn procedure not happening. Fuel Pump primes injectors but no start/click nothing.
Is the BCM most likely dead anyone
Any Suggestions
Old 07-02-2012, 09:01 PM
Tech II Tech II is offline
Just for ha-ha's, have you checked the starter circuit?
Scanned for codes?
please read!! need help.. blondie_12587 Focus | C Max 0 03-09-2009 10:29 PM
i fail smog because the computer din't read any sensor please i need help to pass. duarte_ryb Blazer 5 09-14-2005 08:27 PM
96 Grand AM GT v6 PLEASE READ NEED HELP!!! ag3ntman Grand AM 3 05-18-2005 11:11 PM
Please I need Help Read this Important 95vtecpower JDM Motor & Parts info/chat 1 05-10-2005 12:31 AM
Car Title Transfer Problem! Please Read!! Need Help!! swankz Car Buying Q&A 5 09-23-2003 08:58 AM
