Old 06-16-2012, 12:38 AM
96DEVILLE 96DEVILLE is offline
Tranny swap
I have a 91 camaro trans. I think it is a 350 i am replaceing it with a 700r the tranny tails are differend . I need the tail that has a mount for the torque-arm that goes from tranny to rear end on the camaro .can i just swap then... Also one has a elecrtic. Speedomenter the other doesn t can that be changed. Thank you for your help...carl
Old 06-16-2012, 10:33 AM
Blue Bowtie's Avatar
Registered Offender
Re: Tranny swap
A '91 F-Body should have been delivered with the TH700-R4, even behind the V-6. If it does indeed have a TH350 someone changed it after it was delivered. You would only need to undo the changes someone had done before and restore it to the original configuration,including the torque arm flange and VSS in the tailshaft housing. Make sure you install the correct plastic driven gear (identified by color) on the VSS to match your rear gears.
The Following User Says Thank You to Blue Bowtie For This Useful Post:
96DEVILLE (06-16-2012)
96 cavalier tranny swap with a 94 sunbird gothmoglord Non-Performance 0 10-22-2009 10:30 PM
STD to Si tranny swap with just tranny Shaguar47 '88 - '91 Civic | CRX | Wagon | Shuttlee 9 03-06-2006 08:41 AM
Manual tranny to Auto tranny swap?? zx2racer ZX2 3 02-12-2006 06:27 PM
Svt swap or just tranny swap? shizznizz980 Focus | C Max 1 12-30-2005 09:09 PM
Possable to do a tranny swap like egine swap? DeusEx Camaro Discussions 14 10-17-2005 03:08 PM
