Old 06-11-2012, 02:55 PM
Shelby 427 1965's Avatar
Shelby 427 1965 Shelby 427 1965 is offline
This stuff any good?
Well lads, saw this stuff on eBay, was thinking about getting.. I'm really liking the look of the wet look lacquer I'm seeing around different forums, so I was wondering if any of you have used it?
http://www.ebay.co.uk/itm/500ML-Aero...#ht_1115wt_821
Cheers!
- Tomo
Old 06-11-2012, 03:39 PM
turbothirtytwo's Avatar
turbothirtytwo turbothirtytwo is offline
Re: This stuff any good?
how can be something of 2parts in one can?
Old 06-11-2012, 03:48 PM
roymattblack roymattblack is offline
Haven't used it but I've got a can on order.
I'm going to try it on an 'old' kit already built/painted to see if it makes any difference.
Roy.
Old 06-11-2012, 04:03 PM
leafs004 leafs004 is offline
http://coastairbrush.com/proddetail.asp?prod=3680061
I've used this 2-part clear, and it works by separating the two compounds inside the can. You activate the hardner by pressing a peg on the bottom, then shake well. Once activated, you have 24 hours to use it before it turns solid. Not cheap, but cheaper than having to buy clear and hardner. I was able to clearcoat three 1/12 scale cars, plus three 1/24 scale cars with a minimum of 2 coats. I am very happy with the results.
Old 06-11-2012, 07:21 PM
icon_modeler icon_modeler is offline
I live right up the street from Coast and I have a can of this clear. Can you tell me if it is decal safe. I have two 1/24th Martini 935's I'd like to clear coat but that is a lot of hard decal work to cover with a clear that I'm not sure about. Any input would be great. Thanks!!
Old 06-11-2012, 08:50 PM
I've had very mixed reactions with decals. I always make sure they are very dry, but some decals react poorly, the edges start to wrinkle, while other times they do not. I have not had a problem with newer Tamiya decals, but I have had issues with other decals and some aftermarket ones. I would not recommend using the clear on the Porsches as your first subject. I can take a few pics to try and show you some of the results but it is so subtle that you may not be able to see it.
Old 06-11-2012, 10:31 PM
Thanks for the info. The cars are a mix of old and new decals. I'm sure they are dry enough, they have not been touched in two or three months
This leaves me with not many options. I guess I need a practic model, wait, that was what these are supposed to be
My problem is that I feel more then comfortable with a spray can. I have some Zero 2K clear but I have not used an airbrush in almost 30 years and do not want to start on these cars.
Wish me luck
Old 06-12-2012, 01:02 PM
jano11 jano11 is offline
Wish me luck
Good Luck!
is this one any good? mike5721947 General Discussion 2 04-20-2005 10:31 AM
Is this car any good? quinnjere Celica 8 08-24-2004 12:21 AM
thinkn of buying this tamiya... any good IntegraTypeR186 Remote Control Cars 7 12-24-2003 05:56 PM
Is this BOV any good? HondaSi88 Forced Induction 7 09-28-2003 11:34 PM
Is this spec any good ragt20 COMPLETELY off-topic 20 04-13-2002 08:15 AM
