Old 06-10-2012, 12:13 AM
grt grt is offline
How much freon do I need?
Does anyone know how much freon the system holds on a 00 GP GT? Also how much a/c oil does the system need? I plan on evacuating the whole system and reinstalling Redtek freon, i also have a can of the oil but not sure if i have to put the whole can in?
Old 06-10-2012, 09:54 AM
danielsatur danielsatur is offline
Re: How much freon do I need?
What makes Redtek better than 134a?
Redtek should have a number for Technical assistance.
Old 06-10-2012, 12:12 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
I highly suggest that unless you have the proper equipment to do evacuation and reinstall that you take it to a shop and spend the $50 or so to have them do it.
There is no reason to evacuate unless you have to remove the system. Top it off and be done with it.
Old 06-10-2012, 01:15 PM
grt grt is offline
if it was that simple and only cost 50 dollars, believe me i would
Old 06-10-2012, 05:23 PM
Stealthee's Avatar
Then don't evacuate. Top it off and be done with it.
Old 06-10-2012, 05:27 PM
Yes - it's that simple!
Make sure your engine is running with the air cond on high max, and use a proper gauge.
Big Lots - $10 a can for 134a
Old 06-10-2012, 08:04 PM
grt grt is offline
the compressor is very noisy thats why I thought maybe it needs some oil, and there r no metal shavings down by the compressor clutch
Old 06-10-2012, 08:44 PM
DeltaP DeltaP is offline
A noisy compressor can be low on oil or getting ready to take a dump.(usually because its been running low on oil). Make sure its not the belt making the noise. Sometimes they'll sound like a rattle snake just before they go! Then sometimes you can put in an ounce or two of oil and prolong them. Use the correct weight oil with the dye tracer in it.
how much is needed nova_scotian_guy Auto Collision Network 0 02-17-2010 04:57 PM
How much Freon to charge AC system JasonL12 Ninety Eight 4 07-15-2008 09:30 PM
How Much R12/Freon Needed tbertsc How-To's and Walk-Through's 4 07-30-2006 08:29 PM
How much A/C oil and Freon barryboy Sentra | 200SX (USDM FWD) 0 10-29-2004 08:06 AM
How much freon? barryboy Accord/TSX/Accord Hybrid 0 07-26-2004 01:56 AM
