Old 06-05-2012, 09:58 AM
CrazyHorst CrazyHorst is offline
2000 GTP - metal fuel bundle replacement
Need some helpful advice on replacing the metal fuel line bundle travelling from the tank to the engine. I replaced a brake line to the passenger side front brake caliper last fall and was not exactly thrilled about the condition of the fuel lines (pressure, return, EVAP)
Ideally I'd like to replace the entire lines, I don't have a problem bending tubing, the problem is more around the special endforms if I wanted a single piece.
Although I'd never use a compression fitting on a brake line I think I'd do that for a fuel line since its only ~60psi.
Any other options out there? Dealer new? Thanks for your advice.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 06-05-2012, 05:21 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2000 GTP - metal fuel bundle replacement
Unfortunately you will need to check with a dealer. There is a good possibility that these fuel lines are no longer available for your car. You may need to go to a wrecking yard to see if you can find a good set of lines. The fuel rail at the engine is available but I have checked several places and do not see an item for the fuel lines to the tank. Good Luck!
2000 GTP Blowing Fuel Pump Fuses dueyb1970 Grand Prix 2 03-25-2014 09:58 PM
2000 GTP No Fuel dehthnotez Grand Prix 7 09-21-2013 06:43 AM
2000 Olds Silhouette Fuel Pump Replacement scottp6 Silhouette 11 08-03-2013 12:19 AM
2000 Gtp Window Motor/Regulator Replaced With Unit Off Of Ebay wht-tail Grand Prix 2 10-21-2006 09:08 PM
2000 Grand Prix fuel pump replacement. Grim4208 Grand Prix 6 07-17-2006 12:11 PM
