Old 10-17-2009, 10:16 AM
dueyb1970 dueyb1970 is offline
2000 GTP Blowing Fuel Pump Fuses
Hey everyone, Been having an issue with my car blowing fuel pump fuses every once in a while under heavy to moderate acceleration. Have replaced inline fuel filter and the fuel pump resister(white ceramic part). Runs fine with normal driving, but when i want to get some horses out of it, it will cut out and stall and once i replace blown fuse it will start back up again, and I'm off and running again. Any help would be greatly appreciated.
Old 10-17-2009, 10:27 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 2000 GTP Blowing Fuel Pump Fuses
Sounds like the pump is pulling too make amps. You could check out your grounds back there, but usually when they run high amperage, it means they are spinning faster than normal, and are on their last leg.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 03-25-2014, 08:58 PM
fmx_guy's Avatar
fmx_guy fmx_guy is offline
I see that this is an older thread but my brothers exact same car does the exact same thing. He bought the car 1 yr. old it's been doing this since 01. You just can't run full boost from the charger. Anyone fixed this problem?
