Old 05-28-2012, 03:18 PM
dogkatcher's Avatar
dogkatcher dogkatcher is offline
90 XJ .. front axle shaft & hub .. can you drive without axle shaft? 2 hubs wrecked
1990 xj laredo 4x4, 4.0l ... 157k ... vacuum engage front drive .. axle shaft u joint got loose, noisy
so ... someone told me I could drive without axle shaft (passenger side), just in case the axle shaft I bought didnt fit, then I could drive & match the part after I pull it out (free swap). made sense unless I needed 4 wheel drive
just so happens, the axle shaft bought has different spline pattern. so put old hub back on, drove around yesterday (-axle shaft), things got noisy
this AM .. found the hub assy is very loose. I figured I messed up the old one using the hub puller on it
bought a new hub assy, installed it very carefully (-axle shaft) .. drove around block a few times to let brakes settle in, turns out new hub is loose now too, very wobbly
I guess the axle shaft needs to be in there? really doubt a brand new hub would go bad
thoughts? thanks
Old 05-28-2012, 08:34 PM
dogkatcher's Avatar
Re: 90 XJ .. front axle shaft & hub .. can you drive without axle shaft? 2 hubs wrecked
so .. I received an answer on a cherokee forum.
http://www.cherokeeforum.com/f2/1990...9/#post1799374
MY PERSONAL NOTES 1ST .. I wouldnt even write all of this, but the wheel hub coulda exploded on highway yesterday .. not cool
For everyone out there .. dont listen to guys at used parts places that dont put their best foot forward .. the guy left me alone to go thru a shelf of used axle parts, he didnt care about me at all .. after him saying "do you have the old one? to match it up" .. I asked about driving without it, to bring it in to match it .. he says "yea you can drive without it" .. not so .. according to cherokee forum .. a no brainer what axle it is, Dana 30 .. and NO you cant drive without .. this used place is a jeep specific place .. makes me wonder .. hopin they honor the free swap since no match .. if not, ouch (I dont wanna go there yet, im in a good mood)
thanks to this man !! jeeps runnin safe .. hindsight says I shoulda started that thread sooner
just need to swap the mis-bought part .. learned alot .. especially removing / re-installing parts up there .. cleaned up 22 year bolts, they look almost new ... 3rd round it was a breeze .. so the 4th time: installing the correct axle shaft will be easy (knock on wood)
to boot got 2 bike rides to parts place today, quite a memorial day workout .. the rides relieved some stress too, great cool colorado weather
Big Thanks to Nor-CalJeeper via cherokeeforum.com
his quote:
on the xj the ONLY safe way to drive the d30 with out in axle in place is to remove the ujoint from the axle and reinstall the axle stub through the hub unit and retorque the nut. driving around like that means that the unit bearing was the only thing holding your wheel on which it isn't made for and is very very dangerous.
You were lucky it didnt break but I am sure the unit bearing is probably no good now.
Old 05-29-2012, 08:14 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Hey dogkatcher, thanks for posting up the answer.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
umm what happens when you drive without brakepads for a while? yourdeathwish S-10 18 03-08-2017 09:12 AM
Can you drive with just headers? 79Bandit Camaro Discussions 15 03-16-2007 09:02 PM
Can you go without Heat shield????? batman19 '96-'00 Civic 5 02-20-2006 11:12 PM
Can you run without Vtec? Masta '88 - '91 Civic | CRX | Wagon | Shuttlee 8 01-10-2004 07:20 PM
How well can you drive? dayna240sx COMPLETELY off-topic 12 12-05-2003 04:05 PM
