Old 05-20-2012, 05:06 PM
TimmyGTP02 TimmyGTP02 is offline
Door won't open
Hello, I have a 2002 grand prix gtp 4 door and the passenger front door won't open and I need some help. It won't open from the outside or inside, and when I first unlocked the doors it didn't fully unlock so I manually unlocked it but still won't open from either side. Since the door doesn't open I can't get the trim off to see what's going on. Anyone have any ideas?? THANKS!!!
Old 05-20-2012, 05:24 PM
DeltaP DeltaP is offline
Re: Door won't open
Try a slim jim. But you'll have to get down to the latch and hopefully catch onto the release lever. Maybe AAA can help ya but they usually hook onto the linkage rod between the latch and the lock button/lever on the inside handle, which is probably unhooked causing the problem. HTH
Old 06-01-2012, 09:33 PM
Re: Door won't open
Thanks for replying. Sorry it took me so long to say so but haven't been on much lately. I will have to see about getting a slim jim.
Old 06-02-2012, 08:30 AM
Tech II Tech II is offline
Re: Door won't open
If you can't get the slim jim to work on the passenger side, what I would do is remove the door trim and peel back the water barrier, and "practice" with a slim jim on the driver's side........that way you will have a "feel" for it on the passenger side.....
Unfortunately, it's unusual for the linkage to come off for the inside and outside door opening handle/latches...... what I have seen is, a rust problem in the latch itself.....if that's the case, that door panel will have to be removed(can be done), and a penetrant will have to be sprayed on the latch mechanism, and all the linkage connections will have to be manually manipulated, repeatedly.....eventually, it should open....will take patience.....
Door won't open - wind whipped door back Velvet's Fire General Discussions 7 02-25-2017 02:55 PM
Rear Doors Won't Open bdzb1234 Econoline 2 05-06-2010 11:34 PM
03 Optima Door Won't Open cmbsound Optima | Magentis | Lotze 1 09-30-2009 11:34 PM
Rear door won't open. Dan_in_WA Montana/Montana SV6 4 06-20-2008 08:11 PM
Door won't open on 88 Lesabre lsi11111 LeSabre 2 05-19-2004 10:19 PM
