Door won't open on 88 Lesabre
A locksmith tried to open the front passenger door, and when that didn't work he popped the rear passenger door instead. Now the front passenger door won't open. So my question is how do I get that door open to fix whatever is wrong with it?
Thanks |
Re: Door won't open on 88 Lesabre
did anyone answer the door not opening question thanks
if you unlocked the car and the inside and outside handle are not working you will have to remove the inner door panel and see if the rod came off or the latch is broken if the rod fell off you can usually pop it back on without a problem the only problem is getting in the door when it is closed you will probably have to remove the front seat ot get the panel off
