Old 05-18-2012, 02:56 PM
Jbrowneng Jbrowneng is offline
96 Plymouth Voyager 3.3L Suddenly Stalls & Shifting Problem (Related?)
Sorry if you've read this already. I don't know how to alter my heading on my last post, but I put the year of my mini-van as 1995 when it is a '96.
I have two problems I believe may be related, but am not sure.
1st problem is shifting from 1st to 2nd and sometimes from 2nd to 3rd though, 2nd to 3rd is not as bad as from 1st to 2nd. It stumbles and gets really bad if I don't let up on the gas. After the initial shudder it will go into 2nd just fine. I also have to gun the gas a little bit when I first start the car, or it will just sit there and idle and never go into gear.
2nd and more annoying is that it stalls after driving around a bit. It happens on freeway or city. It doesn't stutter or anything the rpm's drop to 0 and it just stalls and won't start up for a 5 - 10 minutes or so.
Codes pulled are P0731, & P0736. The transmission was replaced about 2 years ago with a refurbished one. Could it be going out again already? The guy at Autozone suggested replacing the TSS (Transmission Speed Sensor?) to see if that was the problem. I have not done this yet, but plan to. Any other suggestions.
Old 05-18-2012, 06:22 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 96 Plymouth Voyager 3.3L Suddenly Stalls & Shifting Problem (Related?)
Stalling - Crankshaft/camshaft sensors would be high on my list. Fuel pump would be another.
Shifting - Gear ratio error codes suggest worn clutches. Have a shop read the clutch volume index numbers and check for internal transmission codes. These aren't the codes read with an ordinary scanner. Might try a fluid/filter change.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
jamesslcx (05-21-2012)
Old 05-22-2012, 04:19 PM
Thanks for the suggestions. I am going to change the transmission speed sensors (inner & outer? terminology?) and I will post back results. Crankshaft & camshaft sensors will be next. Lastly for obvious reasons will be the fuel pump.
After that I will take it in for readings from a shop for the internal transmission codes.
Thanks again!
Old 05-27-2012, 09:28 AM
OK, changed the TSS sensors and no change. Searching on Youtube for easy way to change fuel pump came across a possible cause for one of my problems, the stalling. I've included the webpage below. The response to her video is below as well. This girl threw everything at this car. All sensors, fuel pump and more! No change. I am afraid I am starting down the same path. Please tell me what you think about the cause that this guy lists in his response.
Response from Youtube page:
"A shame techs simply threw parts at it & hoped. "Remove & Replace" troubleshooting. This expensive way to do it. How about RESEARCH. I had a problem that lasted for several years
but wouldn't agree to R&R. I found it at the library TSB 18-12-98.The car hesitated & would stall when hot. Dodge had problems w/WIRING from sensors to computer. Fix was a new wire run from the forward O2 sensor to the computer. Fixed it. I read problems too in wiring from coolant temperature probe: Fix? New connector."
http://www.youtube.com/watch?v=s9skJjI3F-c
95 Plymouth Voyager 3.3L Suddenly Stalls & Shifting Problem (Related?) Jbrowneng Caravan | Voyager 0 05-18-2012 10:39 AM
1998 Plymouth Voyager 3.3L allenprimo913 Caravan | Voyager 7 04-12-2010 02:29 AM
Problem starting a 1994 Plymouth Voyager 3.0L WaOnFiRe Caravan | Voyager 2 04-20-2009 02:58 PM
1994 plymouth voyager 3.3 engine-won't start epmd106 Caravan | Voyager 2 01-23-2008 11:20 PM
1991 Plymouth Voyager 3.3l V6....Not running Junky1991 Caravan | Voyager 3 11-21-2005 07:29 PM
