Old 05-18-2012, 10:39 AM
Jbrowneng Jbrowneng is offline
95 Plymouth Voyager 3.3L Suddenly Stalls & Shifting Problem (Related?)
I have two problems I believe may be related, but am not sure.
1st problem is shifting from 1st to 2nd and sometimes from 2nd to 3rd though, 2nd to 3rd is not as bad as from 1st to 2nd. It stumbles and gets really bad if I don't let up on the gas. After the initial shudder it will go into 2nd just fine. I also have to gun the gas a little bit when I first start the car, or it will just sit there and idle and never go into gear.
2nd and more annoying is that it stalls after driving around a bit. It happens on freeway or city. It doesn't stutter or anything the rpm's drop to 0 and it just stalls and won't start up for a 5 - 10 minutes or so.
Codes pulled are P0731, & P0736. The transmission was replaced about 2 years ago with a refurbished one. Could it be going out again already? The guy at Autozone suggested replacing the TSS (Transmission Speed Sensor?) to see if that was the problem. I have not done this yet, but plan to. Any other suggestions.
2002 Voyager 3.0L quit suddenly no spark dieterschmied Caravan | Voyager 9 03-16-2012 02:31 AM
Oil pressure 1999 voyager 3.0L engine dieterschmied Caravan | Voyager 7 04-19-2011 09:53 PM
1999 grand caravan se 3.3L HEATER Tyson_baker Caravan | Voyager 4 01-24-2011 03:24 PM
1998 Plymouth Voyager 3.3L allenprimo913 Caravan | Voyager 7 04-12-2010 02:29 AM
1991 Plymouth Voyager 3.3l V6....Not running Junky1991 Caravan | Voyager 3 11-21-2005 07:29 PM
Tags
plymouth , stalls , voyager
