Old 04-17-2011, 12:28 AM
dieterschmied dieterschmied is offline
Oil pressure 1999 voyager 3.0L engine
The oil pressure symbol is lighting up and chiming. I just replaced the sending unit and it is doing the same thing. It usually happens when it is stopped and idling but lately it has occasionally occurred after driving for an hour or more while going down the Xway.
Oil is new, filter is new, sending unit is new.
There is a slight oil leak which I can smell hitting the exhaust. Less that an ounce in a hundred miles.
I think I can rig up a gauge to the sending unit port; what should the pressure be?
Any other suggestions?
Old 04-18-2011, 08:34 PM
b1lk1 b1lk1 is offline
Re: Oil pressure 1999 voyager 3.0L engine
Anything less than 20PSI on a mechanical guage at any time is a bad sign.
The Following User Says Thank You to b1lk1 For This Useful Post:
dieterschmied (04-18-2011)
Old 04-18-2011, 10:06 PM
Thanks.
The oil icon has not been lighting up this week. Is anyone experiencing any problems with the sending units. I have vehicles from the fifties and never have had problems with the sending units. This year , I have had two; one was leaking the other was just a suspect.
Generally, when I have experienced low pressure , it would show up in the lifters. I am not seeing that here.
Old 04-19-2011, 06:50 AM
While I agree that you usually see other signs when oil pressure is low, I would not trust anything else but a mechnical guage to prove oil pressure. It only takes one bearing spinning due to lack of oil to take out a whole motor.
dieterschmied (04-19-2011)
Old 04-19-2011, 10:51 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Found this in a post on another forum:
The 1998 Chrysler Caravan Service manual says on page 9-90:
For 3.0L engine.
Oil pressure at curb idle speed = 10 psi.
At 3000 rpm = 45 to 75 psi.
In previous years the low limit was 6 psi at idle.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
Old 04-19-2011, 11:31 AM
The dilemma is that short of an oil pump or relief valve , if there is one, any repair will involve removing the engine, unless there is some unique problem common to this engine. At this point I am guessing. I'll run the pressure test and ...
Old 04-19-2011, 11:33 AM
While I agree that you usually see other signs when oil pressure is low, I would not trust anything else but a mechancal guage to prove oil pressure. It only takes one bearing spinning due to lack of oil to take out a whole motor.
The dilemma is that short of an oil pump or relief valve , if there is one, any repair will involve removing the engine, unless there is some unique problem common to this engine. At this point I am guessing. I'll run the pressure test and decide.
Old 04-19-2011, 09:53 PM
Only way to test oil pressure properly is with a known good mechanical guage. That will tell you what the pump is doing. A bad relief valve, which I believe every engine has of some type, will usually fail with no pressure or high pressure. I believe these engines have the pump driven off the crankshaft at the timing cover. The relief valve could possible be accessed externally, but I cannot remember for certain. Either way, anything short of a miracle of the pump/valve failing (which is not common) then the engine will need an overhaul. The only oiling problem that comes to mind to me for the 3.0L engine was upper end oiling/lifter issues. They are not known for other failures in the oiling system.
dieterschmied (04-20-2011)
procedure to remove engine & transmission dieterschmied Caravan | Voyager 0 04-17-2011 12:14 AM
96 windstar 3.0L tramission problem Steve45ca Windstar 3 01-17-2010 04:56 PM
2001 Denali Low oil pressure w/ engine noise diddy0230 Yukon 1 05-11-2009 07:27 PM
Fuel Tornado 2000 grand voyager 3.0L engine, any thoughts? dealseaker Caravan | Voyager 5 07-26-2006 08:33 AM
98 Voyager 3.0L engine light again Amechanic Caravan | Voyager 1 03-08-2006 01:11 PM
Tags
3.0l , oil , plymouth , pressure , voyager
