Go Back   Automotive Forums Car Chat > Buick > Regal
Old 05-03-2012, 05:52 PM
caddiali caddiali is offline
Rear window does not go up
97 Regal 203kms
My rear drivers side window does not go up with the button..It is making a small noise like the motor is trying to but is stuck. I had to use my hands to force it up. Does anyone know what the problem is?
Thanks for your ideas and feedback!
Old 05-03-2012, 07:03 PM
FishFind FishFind is offline
One Hot Shot
Re: Rear window does not go up
Motor could be going out. Or a weak or low signal.
You need to take the door panel off and see if you have 2 or 4 wires that go to the motor.
If you have 4 then you should have 2 wires for up and 2 for down. Check the wires with a volt meter. If you have 2 wires then it should be like 12v up and -12v when down. It could also be the switch its self. If you have a drivers switch and a switch in the back then see if neither work.
Old 05-03-2012, 09:47 PM
Tech II Tech II is offline
Use a test light instead of a voltmeter.....
Should only be two wires going to the motor.....can just pop off door switch and attach test light to the two wires in the harness going to the motor(don't disconnect the harness from the switch)....now operate that switch or the master switch up and down......test light should be bright in both directions.....if it is and the window doesn't move well, then it's a bad motor and/or regulator.....
Old 05-04-2012, 04:18 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Most likely the window regulator assembly. I've replaced all 4 on on my '99 Regal LS. None of the motors were bad so I reused them. BTW - You can purchase just the regulator assembly without the motor or get one with both.
Timeslip 08/12/06
AF Community Guidelines
Old 05-04-2012, 06:48 PM
Thanks for the quick and accurate reply. Whats the price range for the window regulator assembly?
Thanks again!
Old 05-05-2012, 05:10 AM
BNaylor's Avatar
Are you in the U.S. or Canada? $35 from PartsPro based in Louisiana.
Timeslip 08/12/06
Old 05-05-2012, 07:48 AM
Im in Toronto, Canada...
Old 05-05-2012, 09:36 AM
Does the window tilt to one side or the other as it goes up or down?
Old 05-06-2012, 10:18 AM
No tilt to either side. When the switch is pressed the glass will sometimes go down. But fully stopped going up altogether.
ALSO: the rear power window button (both) aren't working, up or down. What is the cause of this?
Thanks for the help!
rear vent window does not open 86Sebring Caravan | Voyager 7 04-03-2009 03:11 PM
1998 towncar window does not roll up jissle Town Car 3 04-26-2007 02:37 PM
Power Window does not work!! ryan_guest1985 1st Gen 95-99 1 05-26-2005 09:17 AM
1993 accord window does not close! IIcrazedIl Accord/TSX/Accord Hybrid 8 12-01-2004 06:04 PM
