Old 12-16-2003, 09:33 PM
IIcrazedIl IIcrazedIl is offline
Question 1993 accord window does not close!
When you close the drivers window it pops out! I took it to get looked at and they said it was the wheather stripping which was then replaced!
But it still does the same thing. They said it is not off track. What could it be?
Old 01-07-2004, 02:11 PM
pressoranks's Avatar
pressoranks pressoranks is offline
Re: 1993 accord window does not close!
Mine does the same thing. I have given up on it - pull i t in with my finger when I am putting the window up.
Old 01-08-2004, 12:53 AM
Maple50175 Maple50175 is offline
Send a message via Yahoo to Maple50175
haha yeah mine did that... its because the window comes out of the track u need to take the door panel off and realine the window once u take it apart and loook you will know what i mean.....
http://www.cardomain.com/memberpage/467543
My sweet ride :-[
Old 03-28-2004, 09:29 AM
bobcov bobcov is offline
Re: Re: 1993 accord window does not close!
Hi,
Where can I find diagrams/information on how to remove the door panel? I have heard about clips needing to be popped, but i don't want to break anything by doing this without instructions.
-Bob
Old 03-28-2004, 02:25 PM
92lx 92lx is offline
pretty simple to do it, remove all the screws that are hidden behind the obvious "plugs". Then I usually start at one of the corners and either use a specialized tool for popping the clips, or I usually just use a screw driver since it's closer, and pry up just a little, and then yank on the panel a bit. You don't have to be godzilla about it, but don't be afraid either. Once all that is done, you'll need to free the door handle, which I usually accomplish by just twisting the door handle a bit and sliding it through the hole (you'll see what I mean).
See if that helps, and reply with any questions.
- Nathan
Old 03-28-2004, 10:20 PM
Igovert500's Avatar
blue + red light magnet
I had the same problem....2x. Don't worry too much about taking the door apart, I did it the first time in 15mins(maybe less?) on my 90 Ex. the problem was not htat hte window was out of hte track, but rather that the metal bars in the shape of an "x" that unfold to lift the track and then fold down again to lower it. One side of this "x" had gotten bent from use and now could not fold down on itself again, locking hte windown 3/4s of hte way up. I took this metal x out and hammered the hell out of it to make it straight. I put it back in and 2 weeks later it happened again. So if this is hte problem I would recommend reinforcing it somehow, or replacing it, rather then just bending it back. Good luck
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 04-04-2004, 12:59 PM
Hi, Nathan
I took the door apart using your advice. Very simple. Not so simple, understanding what I saw inside.
The window rocks back and forth (front to back) and this is what is causing it to not stay in the rubber seal as it rolls up.
It looks like some kind of a nylon or white plastic fitting may need to be replaced. I could see the steel track that the fitting sits on and I could see that the fitting has too much play in it. If that fitting has to be replaced, how do you do it?
-Bob
- Nathan
Old 06-13-2004, 07:09 PM
mukker22 mukker22 is offline
window coming out of moulding
Has anyone solved this problem without great expense? It appears as all accords of this same couple years have this problem.
Old 12-01-2004, 06:04 PM
Re: window coming out of moulding
Yup problems solved. All the bodies rusted away leaving the tranny and engine. Engine still runs great.
1What does it mean when a 1993 Honda Accord needs an service tune up? tools951 Accord/TSX/Accord Hybrid 1 02-12-2011 01:06 PM
93 villager no click no crank no start klee2183 Villager 1 02-28-2009 08:04 AM
1994 Toyota Camry Window Will Not Close ItsBusted Camry/Camry Hybrid/Vista 3 04-07-2006 05:27 PM
Rear Window will not close Noonoo '93 - '96 0 07-22-2005 09:52 AM
1993 Accord Windows Hagg Accord/TSX/Accord Hybrid 3 01-22-2005 11:08 AM
