Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 04-26-2012, 08:27 PM
bigfartter bigfartter is offline
Heres a good one! (window)-2009 sierra
I searched the forum and did not find another post like this one.
My passenger side power window does not work from the drivers side control, but works from the passenger control. I replaced the master switch on the driver side and it still does not work. I have checked the fuses--Side, below and under the hood and have even found inline fuses below--all were good. Could the dealer have to program my new switch? I do not have child safety locks. Any suggestion would be great--Thanks
2009 sierra standard cab work truck
Last edited by bigfartter; 04-26-2012 at 10:36 PM. Reason: how do you tell if a circuit breaker goes bad??
Old 04-26-2012, 11:09 PM
FishFind FishFind is offline
One Hot Shot
Re: Heres a good one! (window)-2009 sierra
I would check the wires from the drivers side to the pass side. or where it connects to the pass side from the drivers side. I am sure you will find your problem. Use a volt meter.=)
The Following User Says Thank You to FishFind For This Useful Post:
bigfartter (07-19-2012)
Old 04-27-2012, 08:12 AM
GMCustomerService's Avatar
GMCustomerService GMCustomerService is offline
If you do end up working with a dealer on this, let me know! I'm available to assist in whatever way I can.
All the best,
Sarah
GM Customer Service
If you are good at puzzles, I've got a good one for ya savannaz34 Jimmy 1 09-24-2011 01:05 PM
Here is a good one.. Highbeams make my tailights go out.. droop Cavalier 17 12-31-2005 06:53 PM
haven't had a good race in a while but a couple good ones last night RiCR-wana-b Street Racing 7 10-07-2005 07:12 PM
Here is a good one about EGR valves **UPDATED 19/AUG/2004** mcalvo Metro 0 08-19-2004 02:10 PM
Here is a good one about EGR valves mcalvo Metro 4 08-17-2004 02:08 PM
Tags
control , fuses , sierra , window
