Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 04-24-2012, 09:15 AM
mark44004 mark44004 is offline
2001 Jimmy shifts into 4wd on freeway on its own.
Got a 2001 jimmy. When I'm traveling down the freeway at speeds of 60 mph or more, the suv shifts from 2wd into 4 wheel drive on its own. I have to stop and you can tell its in 4wd as it makes the whirring noise as i go to stop. Servo, actuator, ? any helps? Thanks.
Old 04-24-2012, 10:12 AM
FishFind FishFind is offline
One Hot Shot
Re: 2001 Jimmy shifts into 4wd on freeway on its own.
Change the selector switch first. Most of the time it is the problem. After that from what I have heard its the TCCM. Do the switch first though. They are like $30 and most of the time this is the fix.
Old 04-24-2012, 01:30 PM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: 2001 Jimmy shifts into 4wd on freeway on its own.
Agreed, they were troublesome on all the GM trucks including mine.
Old 04-24-2012, 05:04 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Also, look at the conectors to the TCCM, they are prone to get water in them and the terminals get corroded. If you see green fuzzys, that is not good.
Old 05-07-2012, 02:45 PM
snorander's Avatar
snorander snorander is offline
I had this problem for a long time in my 2001 jimmy. It would shift in & out of 4wd hi on it own all the time. I replaced the selector switch, the TCCM and it did not go away. It turns out the vacum switch on my transfer case was bad an let fluid into the vacum lines. Crawl under your truck unplug the vacumn line from the top of the transfer case and see if any fluid drips out. If it does you need to let the lines drain and replace the vacum switch. It worked for me & I have had zero problems since. It is a lot cheaper to replace the vacum switch
Please Help, '99 AT Mitsu Eclipse won't shift into 3rd '99EclipseProblems Engine, Transmission and Drivetrain 6 09-13-2009 10:03 PM
2000 Blazer Shifting Into 4WD On Its Own While Driving. jimgunthorpe Problem Diagnosis 3 02-04-2009 10:20 AM
2000 S10 goes into 4wd on its own pizon6979 Problem Diagnosis 3 09-30-2008 12:05 PM
2001 S-10 Pickup switches into 4WD on its own oldebondo Problem Diagnosis 9 07-28-2008 03:16 PM
4wd light blinking, shifts into 4wd, in 4wd grinds in tight turn 4x4passport1185 Rodeo | Passport | MU 2 09-22-2007 08:07 PM
