Old 07-10-2008, 12:48 PM
oldebondo's Avatar
oldebondo oldebondo is offline
2001 S-10 Pickup switches into 4WD on its own
4.3L automatic LS, 42,000 miles: Just driving down the road, the 4WD Lo button starts blinking waiting for right conditions to switch into 4WD. If I hit the 2WD Hi button twice, it cancels until the next time. Seems to do this twice a mile or so. Is it the button giving a spurious signal or did a mouse chew through some wires? I appreciate any ideas on where to look. Thanks in advance for your kind and informative replies.
Old 07-14-2008, 01:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2001 S-10 Pickup switches into 4WD on its own
If a 233 transfer case check for codes.
Ground pin 13 diagnostic connector and count light blinks and post back.
MT
MT
Old 07-15-2008, 09:32 AM
oldebondo's Avatar
MT
I checked both with a code reader and as prescribed by you: No codes were set according to the code reader; when pin 13 is grounded, there were no lights on at the 4WD selector switches; no blinking no nothing. What does this mean?
I ordered a cheapy switch off Ebay just to try. My gut feel is that it is the switch but you never know what you don't know until you find out that what you do know is not enough.
Thanks in advance for your informative reply!
Old 07-15-2008, 10:01 AM
MT-2500's Avatar
AF - Advisor
Does the lights come on for a bulb check with key on?
Check all fuses and plugins and wiring.
Also check plugins and wiring on transfer case module.
Let us know what the switch does.
Good luck.
MT
MT
Old 07-15-2008, 12:02 PM
oldebondo's Avatar
Good luck.
MT
Yes, without pin 13 grounded, the lights do come ON for a bulb check when the key is turned ON.
Will the TCCM default to 2WD if the switch module is unplugged? (Assuming the TCCM was last in 2WD.)
Old 07-15-2008, 12:17 PM
MT-2500's Avatar
AF - Advisor
If you get it into 2W and unplug everything it should stay there.
MT
MT
Old 07-15-2008, 12:56 PM
oldebondo's Avatar
Good luck.
MT
Old 07-15-2008, 01:21 PM
MT-2500's Avatar
AF - Advisor
Not sure about the defalt But.
If you get it into 2W and unplug it it should stays there,
MT
Old 07-28-2008, 12:48 PM
oldebondo's Avatar
Wink Re: 2001 S-10 Pickup switches into 4WD on its own
I just wanted to get back and post what my final solution was:
I purchased a replacement switch assy on eBay and the problem went away. I disassembled the original switch and cleaned some "black stuff" from the space between the contacts using IPA and a Q-Tip.
Old 07-28-2008, 03:16 PM
MT-2500's Avatar
AF - Advisor
Thanks for posting back how it went and the fix.
Glad you found the problem and got it fixed.
Good luck
MT
MT
