Go Back   Automotive Forums Car Chat > GMC > General Discussion
Old 04-17-2012, 08:39 PM
John from Canada John from Canada is offline
'97 305 needs some work
I got this old van that I want to fix up for work. There was a lot of gunk on the front of the motor. When I cleaned it off, I noticed the lower intake manifold gasket pinching out right below the EGR valve, and suspect this might be the source of the gunk. I could live with the truck leaking a little bit of fluid, but is it possible this could be part of a larger problem?
How big of a job is this?
Old 04-18-2012, 07:55 AM
maxwedge maxwedge is offline
A990 racer
Re: '97 305 needs some work
Common issue, not knowing you experience hard to advice you here, in my shop it is a one day job, for the how to try autozone.com, repair guides.
Old 04-18-2012, 10:21 PM
Should I do the repair? Is it like a head gasket, is there oil and coolant getting mixed up inside there with the gasket failing like that? And if I do take it all apart, what else should I do while I'm in there?
305 - Engine Modifications/Rebuild: Need Some Advice PeteA216 Caprice 9 05-30-2010 05:49 PM
Possibly buying a 1995 eagle talon TSI that needs some work. Xalis Off-Topic 3 09-08-2007 02:59 PM
94 grand prix needs some work. How hard? bogart219 Grand Prix 9 09-21-2005 05:34 PM
replaceing 305 with 351, need some help MrFastener Impala | Impala SS 0 04-30-2005 02:31 PM
I Need Some Work Done Pls. CamaroSSBoy346 Graphic Manipulation 3 08-11-2004 05:31 PM
