Go Back   Automotive Forums Car Chat > Ford > Probe
Old 04-16-2012, 10:21 AM
pdallard pdallard is offline
94 Probe - Reverse, Backup Lights Not Working
Thanks for this great Forum!
Just changed the backup bulds, fuse is good but no lights when I put it in reverse. I see from a diagram there is a "back up lamp Switch" located to the left of the battery. Is this an actual bulb or an inline fuse & should it fix my problem? I can't seem to find the damn thing.
Thanks for any help
Old 04-16-2012, 08:58 PM
tempfixit tempfixit is offline
Re: 94 Probe - Reverse, Backup Lights Not Working
Thanks for any help
Manual or automatic tranny??? THe neutral safety switch normally controls the back up lights.
Old 04-17-2012, 07:00 AM
Thanks for your reply!
Sorry about that it's a 5 speed (Base) 2.0L - So where would the neutral safety switch be located? I think I located the back up lamp Switch, it sits between the battery & the plugs with a small female wire fitting, the switch looks like it screws into a portion of the block-
Thanks again!
Old 04-17-2012, 09:00 PM
Gon to www.autozne.com and look up back up switch, it will show you apicture of the switch. That should help you indentify the switch.
Tail and Backup Lights NOT Working ezmak Problem Diagnosis 1 10-08-2010 09:24 AM
Rear Signal Lights, Brake Lights, and Backup Lights not working jimbo831 Cavalier Problem Diagnosis 2 08-23-2010 04:08 PM
backup lights not working fmrjmr Grand Cherokee | Grand Cherokee SRT8 3 12-03-2004 03:21 PM
backup lights not working in 1972 Chevelle spacecrow Chevelle 4 09-03-2004 10:37 AM
89 Camry Backup Lights not working jomayo1 Camry/Camry Hybrid/Vista 3 04-20-2004 03:27 PM
