Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 11-29-2004, 02:20 PM
fmrjmr fmrjmr is offline
backup lights not working
I replaced the bulbs and the backup lights still do not work. Is there anything else I can check????
Old 11-30-2004, 10:23 AM
Caribbean ZJ Caribbean ZJ is offline
Re: backup lights not working
do a search for (NSS) Neutral safty switch, its
probably dirty
Old 11-30-2004, 11:41 AM
89ltd 89ltd is offline
Hey there young fella, do you have auto or man trans, the neutral saftey switch on the side of the transmision sends the signal to the reverse lights, if both don't work, prob it. Download NSS rebuild,http://www.lunghd.com/Downloads_and_Links/Downloads.htm
Old 12-03-2004, 03:21 PM
Off_Road's Avatar
Off_Road Off_Road is offline
fmrjmr []
backup lights not working (Post #1)
Stick the key in the ignition, turn the key to the on position. Don't start the engine, just turn the key to the on position. Push and hold your foot on the brake pedal in order to move the shifter into the various detents. You might also want to set the emergency break. As you move the shifter slowly through park, reverse, neutral, then drive and slowly back again. Have someone watch behind the vehicle to see if by chance the reverse back up lights might flicker or turn on. If they do come on then it could very well be a linkage adjustment.
