Old 10-08-2010, 12:37 AM
ezmak ezmak is offline
Arrow Tail and Backup Lights NOT Working
I just got a 93 s10 4x4 and replaced the bed of the truck with a wooden flatbed. For tail lights i'm using 2 multi function trailer lights. Coming from the back of the trailer lights are 3 wires RED/GREEN/BLACK. Red is for Tail lights, Green is for brake/turn signal & Black is for the Backup lights. The lights are suppose to be mounted to a metal frame, as far as I know, for the ground; but I have attached wires to the three posts on the back of the lights and grounded them to the frame. 'Naturally' I connect Brown to Red, Light Green to Black and Yellow/Dark Green to Green. The Brake lights, Both turn signals and the hazards all work fine but I have no tail lights or backups. I checked all the fuses and they are all good as well. As far as I can tell it's hooked up right and I've spent the last 2 days trying to figure this out! Everything worked fine before I started the project. If anyone can please help I really don't know what else to do.
Old 10-08-2010, 09:24 AM
j cAT j cAT is offline
Re: Tail and Backup Lights NOT Working
with a voltmeter check to see you have a voltage there.
use the battery ground to meter as you probe for voltage at the rear lamps. if you have voltage then it will be a ground problem.
'05 Dodge Ram 1500 - Tail Lights Not Working DodgeRam1500 Ram Pickup | Ram SRT10 10 12-27-2014 12:58 AM
Rear Signal Lights, Brake Lights, and Backup Lights not working jimbo831 Cavalier Problem Diagnosis 2 08-23-2010 04:08 PM
92 CV tail-lights and red light not working IZ1111 Crown Victoria 19 09-08-2007 10:47 PM
backup lights not working in 1972 Chevelle spacecrow Chevelle 4 09-03-2004 10:37 AM
89 Camry Backup Lights not working jomayo1 Camry/Camry Hybrid/Vista 3 04-20-2004 03:27 PM
Tags
backup , help! , lights , s10 , tail
